2014 f4 cutting out at high speed - MVAgusta.net
post #1 of 6 (permalink) Old 07-24-2015, 10:34 PM Thread Starter
It's happened twice,once at low speed once on the highway at speed. Panel reads a fuel fault and engine loses drive. Doesn't shut off just goes to idle and gives me no drive. Some how able to coast across 3 lanes of a busy highway without getting killed but not happy! Once I shut off bike and restart it letting it go through its starting cycle everything is fine again. Has this happened to anyone else? Seems like pretty foolish and dangerous engineering if lose drive every time a fault registers.
Pelagio is offline
post #2 of 6 (permalink) Old 08-12-2015, 12:08 AM
Ive had mine cut out on me. its been a fault with the quick-shifter. The engine still sounds like its engaged, but its actually shut off and being driven by the back wheel (throttle has no effect).
Psyph0n is offline
post #3 of 6 (permalink) Old 08-12-2015, 05:23 PM
dcF41000's Avatar
Funny you mentioned quick shifter. After having issues with mine cutting out during only at highway cruise for about 6 miles and never around city driving. Ignition has been changed throttle and harness has been changed tilt sensor changed and ecu updated still had issues. But after disconnecting the quick shifter switch it stopped cutting out. Bruce from mv USA out of NH is sending me a new quick shifter plug.
dcF41000 is offline
post #4 of 6 (permalink) Old 08-12-2015, 10:24 PM
dcF41000's Avatar
If this helps I'm quoting the head technical advisor from mv agusta USA out of PA
"The tip sensor and side stand switch and quick shifter are the only thing that can cause shut off without error on dash"
dcF41000 is offline
post #5 of 6 (permalink) Old 11-13-2015, 07:04 PM
juan felipe rodriguez's Avatar
I also pass on my f4 2013, my bike at 7000 rpm approx short and turns an orange light on the dash, not may be, it is as if the bike tubiera limiter rev, but 7000 I think it's not right
juan felipe rodriguez is offline
post #6 of 6 (permalink) Old 07-15-2018, 08:56 AM
MarcoM3's Avatar
Same thing happened to me this morning. I was riding at very high speeds (160MPH+) when the engine hesitated and I got a big STOP warning on the dash. I coasted to a full stop, realized the engine was off, turned the ignition completely off and after waiting for a few seconds, it started right up.
Any ideas what could have caused it? First time ever for me.
MarcoM3
2013 MV Agusta F3 675
2012 Ducati Panigale 1199
2013 MV Agusta F4
MarcoM3 is offline
