2012 F4rr - MVAgusta.net
post #1 of 20 (permalink) Old 02-04-2015, 09:23 AM Thread Starter
2012 F4rr
What should I be looking out for on a secondhand 2012 F4 RR?
Any common faults?
Are they a good thing? Owners please chime in.
What's the maintenance intervals on these and what needs doing?
Thanks.
bstar360 is offline
post #2 of 20 (permalink) Old 02-04-2015, 12:27 PM
BigWill's Avatar
I am the original owner of my 2012 F4RR. I had a couple of minor issues. First was the stock fuel/air mixture. I had a PCV installed and it cleared this right up. I had a blinker stop working and it was replaced under warranty. I replaced the stock piece with a STM clutch slave cylinder due to hard to find neutrals after the bike is up to temp. Maintenance intervals are similar to any other sports bike I have owned, though I do oil/oil filter FIY more often than recommended by the manufacturer (because I had been tracking my bike regularly). I consider all of these minor issues and you'll find some of them oft discussed here on this forum.
Good luck!
Will
BigWill is offline
post #3 of 20 (permalink) Old 02-04-2015, 04:13 PM
mar
mar's Avatar
I have a 2012 R with the titanium exhaust. The exhaust is a little too close to the fairing and has burned through the insulation and damaged the fairing.
1995 Ducati 916
2001 Aprilia Falco
2012 MV Agusta F4R
2004 Moto Guzzi Cafe Sport
2004 Triumph Thruxton
1982 Laverda TS Mirage 1200
1975 Laverda SF2
1978 Harley XLCR
mar is offline
post #4 of 20 (permalink) Old 02-05-2015, 12:33 AM Thread Starter
Any pics on the damage?
bstar360 is offline
post #5 of 20 (permalink) Old 02-05-2015, 12:44 AM
wnehme's Avatar
2012 F4rr
The 2012 comes with the non electronic suspension setup. Alot better than the elecrtic suspension setup thats out with the later models.
Also a cable throttle which is a plus no ride by wire which can be hard getting use too.
wnehme is offline
post #6 of 20 (permalink) Old 02-05-2015, 01:17 AM Thread Starter
Too late for me, Just talked to the seller and the bike I was looking at has been sold.
bstar360 is offline
post #7 of 20 (permalink) Old 02-05-2015, 01:45 AM
wnehme's Avatar
2012 F4rr
Theres a cheap 2014 RR on bikesales for $26k done a 1000km. Offer him 24. You never know
wnehme is offline
post #8 of 20 (permalink) Old 02-05-2015, 06:03 AM
minime's Avatar
yeah less things to go wrong too. The front headlights might fog up or get condensation in the glass.
minime is offline
post #9 of 20 (permalink) Old 02-05-2015, 09:27 AM
jomarti1's Avatar
This usualy happens when the fairing is installed wrong.Even if it looks installed right.Check in detail…You might be surprised.
jomarti1 is offline
post #10 of 20 (permalink) Old 02-05-2015, 09:38 AM
mar
mar's Avatar
I cought it rarther early and it not too noticable. I will however try and take a pic tonight.
1995 Ducati 916
2001 Aprilia Falco
2012 MV Agusta F4R
1975 Laverda SF2
1978 Harley XLCR
mar is offline
