2014 F4RR Autoblipper and software queries - MVAgusta.net
post #1 of 46 (permalink) Old 01-15-2015, 07:55 PM Thread Starter
Hi All,
I am the proud owner of a new Dec 2014 F4RR. Man, this thing is nuts!
Even coming from an f3 800, it just continues to blow my mind...
Anyhow.... These models are meant to have an autoblipper for clutchless downshifts right? If so, how do I activate it??
The quickshifter seems to work well, but when I try to do downshifts without clutch the gear level just feels solid (like it would on a normal gearbox) and doesn't seem to want to shift at all without the clutch.
I'm a bit nervous to just stomp my foot on it , as I don't want to hurt my new baby (plus i'm scared as to what it'll do! haha)
On another note, I just got my bike serviced the other day from the dealer at 940km's. When I picked the bike up I noticed that the throttle was blipping on its own with the clutch depressed. This happened after a medium hard pull in 2nd to 3rd. Since then however, it has not reoccured.
Could this be a bug in the latest software release?? Anyone else experienced it?
Any info on either will be much appreciated.
Cheers!
vteckz is offline
post #2 of 46 (permalink) Old 01-15-2015, 10:58 PM
spence88mph's Avatar
Congratulations, awesome bike! The howl they make up high and how they never stop pulling is amazing! The more you ride it the better it feels, took me a while to get used to the almost lazy feeling throttle but after a while it all feels right.
The downshift blipping I believe was a comms issue, something about over promising in their ads before the ecu was finalised. You can get the corse race ecu that has that feature: http://www.mvagusta.com/en/special-p...rr/racing-ecu/ but the standard ecu doesn't do it, maybe they could do it in a software upgrade but they haven't for 2 years... Take it easy man!
2013 F4RR
2013 Brutale 1090
2014 Rivale
spence88mph is offline
post #3 of 46 (permalink) Old 01-18-2015, 02:02 PM
Fragile's Avatar
I like to ride a lot so having a second bike is important for me. My MV is my backup and weekend bike. My Duc is my long range commuter 500+ miles / week. Need to consider that when going to one bike. YMMV especially is you ride much less or don't rely on your bike then I would say go for the 2 to 1 trade. The F4RR '14 won't necessarily let you down but maintenance is frequent so you may lose miles ridden before next service that owning 2 bikes gives you.
'15 Panigale R (2K miles)
'15 Fireblade SP (1K miles)
Los Angeles North
Fragile is offline
post #4 of 46 (permalink) Old 01-18-2015, 08:40 PM
Are Fragile & Willythepooh on the correct thread here?!
2013 F4RR
2013 Brutale 1090
2014 Rivale
post #5 of 46 (permalink) Old 01-20-2015, 06:59 PM
MYF4's Avatar
Hi Guys, I am new to mvagusta.net. I am in Melbourne, Australia.
Just purchased a 2013 F4RR - and yes, it is completely nuts, even though I have only left it on "normal" setting so far. Interested to find anybody else (preferably in Melbourne!) with the same bike to go riding. But apart from that, interested to get advice on the best way to learn all the trickery available on this beast in order to grow with it and get the best out of it.
I am doing a trackday at Phiullip Island on the 9th Feb.
Hey vteckc, I have the same question actually. I can change down without the clutch, but not every time. Certainly, I also dont want to simply stomp on it forcefully. Further, I often seem to find neutrals when employing the upshift/quickshift ... is it just me, or is this typical?
Looking forward to meeting some of you out there.
MYF4 is offline
post #6 of 46 (permalink) Old 01-20-2015, 07:29 PM
flyboyk's Avatar
I am more likely to get a not wanting to shift on the upshift with the quickshift on my 2014 F4. I have had a just a few neutrals. I do think the 7.5 ft lbs torque on the shift lever bolt is a crucial link to the problem.
2014 MV Agusta F4
Moto Guzzi 1100 Sporti
Yamaha R1
Honda CT90
flyboyk is offline
post #7 of 46 (permalink) Old 01-20-2015, 07:31 PM
Smile
Welcome to the forum George
The shifter not constantly working in upshift could be a few thing, try re-adjusting the lever to a more comfortable position to start with.
As for Melbourne riders, have a look over here - http://www.mvagusta.net/forum/forumdisplay.php?f=24
post #8 of 46 (permalink) Old 01-20-2015, 11:48 PM
flyboyk's Avatar
Donsy, what do you think could be other issues with this quickshifter? It kind of defeats the purpose when it can`t be trusted to work. Actually, it totally defeats the purpose. I`ll try any thoughts you have. Thanks!
2014 MV Agusta F4
Yamaha R1
Honda CT90
flyboyk is offline
post #9 of 46 (permalink) Old 01-21-2015, 12:14 AM
Smile
Okay 'whatsename' , first you need to figure out if it's electrical or mechanical.
Are you aware of how the system works, iow, that the pressure as applied by your foot, does two things.
Firstly the electrical side has to happen, iow, the ignition and/or fuelling has to interrupted, this takes the load off the gearbox.
Secondly but in the same movement, your foot has to apply enough pressure to the lever to still move the selector forks and gears in the gearbox, into the next gear.
I've seen many a guy at the track get this wrong, they just tap the lever enough to break the ignition, but not hard enough to shift the gears as they think this happens automatically.
Others have the lever in the incorrect position, not allowing them to apply enough pressure to allow the gears to be moved into the next position.
Hope this helps guys.
post #10 of 46 (permalink) Old 01-21-2015, 02:26 AM
flyboyk's Avatar
Thanks, I will be more conscious of how I move the lever and see what happens
2014 MV Agusta F4
Yamaha R1
Honda CT90
flyboyk is offline
