2010 F4 battery placement - MVAgusta.net
post #1 of 20 (permalink) Old 11-08-2014, 12:49 PM Thread Starter
Hello,
Weeks ago I removed a bad battery without paying attention to how it was placed. Now that I got my new battery, which has the same placement on + - terminals, I am not sure how to place the battery. See attached picture. The + and - terminals should be the other way around but my old battery is the same as the new one. Does anyone have a picture of theirs? The positive cable would not reach the positive terminal if I turn the battery around.
Timaneo is offline
post #2 of 20 (permalink) Old 11-08-2014, 01:01 PM
First, make sure the battery is a sealed unit suitable for any orientation.
Second, install the battery on its SIDE with the terminals facing the bike's LEFT side and with the positive (+) terminal to the rear...
Third, connect the positive (+) terminal leads.
Fourth, connect the negative (-) terminal leads.
post #3 of 20 (permalink) Old 11-08-2014, 01:02 PM
It is good you asked BEFORE hooking up your battery.
These bike don't take kindly to reverse polarity!
Welcome to the madhouse!
Chuck
post #4 of 20 (permalink) Old 11-08-2014, 01:06 PM Thread Starter
The original battery was definitely not on its side when I removed it which is why this is such a mystery to me. Is the side position you describe the original way the batteries are placed from the manufacturer?
The new battery says it is a sealed led-acid airtight battery but it also says it should be installed in an upright position.
Timaneo is offline
post #5 of 20 (permalink) Old 11-08-2014, 01:16 PM
Does the new battery have a vent line?
What is the manufacturer of the new battery?
post #6 of 20 (permalink) Old 11-08-2014, 01:27 PM
Here are the instructions: 2010 Battery Installation.doc
Here is where the manual lives: http://www.teamdouble3racing.com/man...manual-ed3.pdf
post #7 of 20 (permalink) Old 11-08-2014, 01:28 PM
IF you bough a Koyo to replace an existing bad Koyo, you are doomed from the start. Hopefully, you bought a quality battery such as a Yuasa.
post #8 of 20 (permalink) Old 11-08-2014, 01:29 PM
Upright for these batteries means the label instruction up and the terminals on the left while the positive is at the rear.
post #9 of 20 (permalink) Old 11-08-2014, 01:32 PM Thread Starter
Thanks Chuck! That manual will definitely come in handy.
I guess original battery was on its side I didn't even realize it had those side screw holes. I'm going off to install new battery.
Thanks!
Timaneo is offline
post #10 of 20 (permalink) Old 11-08-2014, 01:41 PM
Could you answer the questions asked earlier,please?
