New 1090RR with a paint defect - MVAgusta.net
log in
Forum
Go Back   MVAgusta.net > Models > Brutale
Thread Tools Display Modes
Old 01-15-2013, 04:10 PM   #1
Matt M.
Matt M.'s Avatar
Default New 1090RR with a paint defect
Anybody see this before? It's not so much a scratch as a tear. This is a brand new 2011 leftover. Neither the dealer or I seen this when I picked it up, but later that night I found it. The tear looks much worse in the photo, but I don't want it to spread. After I sent the dealer the pic, he said that they are going to replace the tank at some point under warranty. Perhaps the tank expanding and contracting caused this to happen?
__________________
2011 Brutale 1090RR
1975 Honda CB550 Cafe
Matt M. is offline   Reply With Quote
Old 01-15-2013, 04:14 PM   #2
silentservice703
Location: In Duxbury, MA, USA with Lee and Patty in my heart.
Send a message via AIM to silentservice703 Send a message via Yahoo to silentservice703 Send a message via Skype™ to silentservice703
Default
Interesting.
__________________
Keep your words soft and sweet...for somday you shall eat them!
A government that robs Peter to pay Paul
can always depend upon the support of Paul.
-- George Bernard Shaw
silentservice703 is offline   Reply With Quote
Old 01-15-2013, 06:17 PM   #3
gotojoe
MV in the Registry:
[F4 1000 R]
gotojoe's Avatar
Default
Matt, it's hard to be 100% from the photo..would be clearer in daylight without the flash effect.
To me, it looks like somebody leant over the bike and scratched it with a belt buckle..
joe
gotojoe is offline   Reply With Quote
Old 01-15-2013, 06:51 PM   #4
jones525
Default Was this bike in the crate...
... or on the showroom floor but never titled? If the bike had fuel in the tank its definitely expansion.
jones525 is offline   Reply With Quote
Old 01-15-2013, 06:56 PM   #5
Matt M.
Matt M.'s Avatar
Default
joe
Definately not a belt buckle. The mark is barely noticeable out in the sunlight. It is easier seen in the picture I took believe it or not. The dealer said it might have something to do with the tank expanding. And MV is working on better composites for their fuel tanks at this time .
__________________
2011 Brutale 1090RR
Old 01-15-2013, 06:57 PM   #6
Matt M.
Matt M.'s Avatar
Default
It was on the showroom floor with fuel in it for sure.
__________________
2011 Brutale 1090RR
Old 01-15-2013, 07:58 PM   #7
jones525
Default Then Yes...
It is expansion related. Fortunately, MV will be replacing your tank under warranty. My Streetfighter (Ducati) had thhe same issue. I had the tank coated with a product called Caswell. So far the replacement is doing fine. I'd consider doing a canisterectomy and coating the replacement from MV.
Old 01-16-2013, 04:11 AM   #8
Matt M.
Matt M.'s Avatar
Default
I agree, another ethanol related fuel issue. This ethanol fuel is like poison to any internal combustion engine. Other than attracting moisture if not used up in a month, it eats the rubber fuel lines and swells gaskets. I heard of the Ducati tank issue before. The ethanol fuel actually makes the composite tank swell up. I will look into the liner, and I always treat my fuel with Startron.
__________________
2011 Brutale 1090RR
Old 01-16-2013, 12:26 PM   #9
VoltesV
VoltesV's Avatar
Default
That happened to my bike too, and it was indeed the tank expanding. I didn't know what caused it at the time, and shortly after (month or so?), the bike starting excessive leaking from other areas of the tank during a mid-ride fuel stop.
My shop (Moto-Forza) replaced tank under warranty. I did just as jones525 recommends and had the new tank coated since it was an identical replacement.
__________________
DO or DO NOT; there is no TRY
2009 B4 1078RR
2002 996 X50
1994 FZJ80
VoltesV is offline   Reply With Quote
Old 01-16-2013, 12:30 PM   #10
gotojoe
MV in the Registry:
[F4 1000 R]
gotojoe's Avatar
Default
So the tank is ok so long as you don't actually put fuel in it right ?
vB code is On
Forum Jump
