#1 |
Well today I returned the rear hub ready for the the forth coming riding season here in the uk if the weather arrives bike has covered 18400 miles and last time this was done was 12000 miles ago so thought it was time to do it bearings were fine when I got the hub out no failers but once it was out I may aswell replace and refurb the whole hub another job done on the old girl
But must say I couldn't of done it without the help of john (jds) well when I say help I mean he actually did it for me I just held stuff lol Hub stripped down cleaned and ready for new bearings and seals ![]() ![]() Nice new bearings ready to go in ![]() ![]() ![]() New bearings in new seals and all greased up ready to back into swing arm ![]() ![]() Bike up on a makeshift abba stand can u spot how we did it ![]() ![]() ![]() Here is away of saving urself money buying a Abbas stand guys simply turn the footpegs over and use two axle stands bike is very secure and stable ![]() Whilst she was off gave her some new rear be six mrr race pads lovely All cleaned and fitted ![]() JUST NEED THE BRITISH WEATHER TO GIVE US SOME RIDING WEATHER NOW PLEASE COME ON Like to say a big thank you to john for all the help ( doing the job ) and suppling the bearings and seal kit to start with thanks again mate your a diamond
__________________
Home of the F4 Fibra di carbonio Last edited by MV-Woodster : 01-10-2013 at 01:15 PM. |
| Sponsored Links | |
Advertisement |
#3 |
King of Bling
My pleasure Woodster.. The only problem we had was getting the axle side nut off, which was unusual because it's normally the wheel nut that can be a sod to remove.. I recon you caught the bearing just in time before they began to fail (good catch), but considering the mileage you had out of them, you didn’t do to bad.. It was nice of Scott down at Staples Corner to allow us accesses to his bearing press, otherwise I wouldn’t have been able to do this hub refurbishment.. And he made us a decent cup of tea, which was a bonus considering it was in a non franchise Mercedes dealer… ![]() It was a good idea to turn the foot hanger’s upside down to allow the bike to be supported on the axle stands.. Good thinking Batman.. ![]() I little tip for you guys doing this overhaul at home is to heat the hub up before installing the new bearings and if it’s at all possible (which in 99.9% of cases it isn’t) place the new bearings in the freezer over night, as this helps facilitate the installation of the new bearings . .
__________________
Home of The Original CORSESuperleggera #01 MV F4 Corse Superleggera # 01 Ducati 1098R ELR 1068cc EMAIL : john@jandrdasilva.co.uk “Life is a waste of time, and time is a waste of life. Get wasted all the time, and you'll have the time of your life!”.... Last edited by JDS : 01-11-2013 at 05:43 AM. |
#4 |
![]() Join Date: Nov 2009
Good thread guys. John, Do you think that given the fragility of the bearings that it makes sense as general advice to the home mechanic, when re-furbing the hub to do the disassembly yourself and if you are not experienced in bearing removal and refitting, to hand the unit to an engineer with the bearing press and pay a few quid for piece of mind. That's how you did it and that's how I do it. Once I start thinking of swinging a hammer I take a step back ..; )
With regards to supporting the bike on axle stands and inverting the pegs...I did it this way but there is no need to touch the pegs. The bike should be supported inboard at the peg pivot point. This is the strongest part of the assembly and less of a " lever arm " effect..and of course no need to take the pegs apart.. joe Last edited by gotojoe : 01-11-2013 at 06:16 AM. |
#5 | |
I turned the pegs around just to give a more stable base for stands as I didn't want the tops of axle stands that close to frame plates Over all was a relativity easy job like john says heat hub makes it a lot easier and access to a bearing press was vital So thanks john again mate and thanks to my mate scoot for excess to press and your lad making tea
__________________
Home of the F4 Fibra di carbonio |
#6 | |
Ha ha yes tea is imperative ! Wot I'm suggesting is that if a guy doing this hasn't got access to a bearing press and/or the hands on experience to do the bearing insertion , to go as far as hub removal and then pay a shop £ 10- £ 20.00 to press the bearings in. You guys were on top of things as you had access to a press and knowledge and of course the tea ! As far as supporting the bike is concerned..I have carried out a full bike build and a frame removal twice with this method and bike does not move. The pivot " bracket" is stronger position by far due to less of a lever moment and the mechanical strength of the inboard section of the assembly. just my tuppence worth..Its not too easy to see cracks in the footpegs where they pivot and I'd hate to see a bike tumble if an inverted foot peg gave way... I left the protective shop cloth off for the picture.. joe Last edited by gotojoe : 01-11-2013 at 06:32 AM. |
#7 |
Joe, don't ever ask how we did Carlos's bearings in my garage...Alex can swing a mean hammer...and no one lost an eye!
__________________
Keep your words soft and sweet...for somday you shall eat them! A government that robs Peter to pay Paul can always depend upon the support of Paul. -- George Bernard Shaw |
#8 |
#9 |
King of Bling
Hey Joe Drifting the old bearings out is the easy part and most competent self taught home mechanics should be able to manage that task. So to answer your question Joe, yes I think it's a no brainer not to pay someone to install the new bearings if you haven't got access to a hydraulic press or aren't confident in installing interference fit bearings. I know there is an MV Technical Advise link on the internet showing the use of a normal bench vice to install the new bearings, but I wouldn’t advise that method be used.. The needle bearing cage is so flimsy that is could be easily damaged if installed on the piss.. Also, I recon it’s critical that the RS bearing be installed with the minimal amount of effort to increase its longevity. This is why it’s advisable to heat up the hub casing to aid the installation process. Normally when I support an MV on the axle stands, I remove the foot pegs completely and install a long bolt into the frame plate and rest the bike on this bolt.. Unfortunately, I couldn’t find these bolts and Woodster didn’t have any in his garage, so we improvised with the “ Heath Robinson” affair and inverted the OEM foot pegs.. My problem is that I want to install a set of magnesium frame plates on my F4 and have no means to do this swap over with the limited facilities I have in my own garage.. I’ve never done this frame plate swap over before and I’m not looking forward to doing it either.. Truth be told, it’s one of the main excuses that’s been holding me back from doing my F4 project bike.. PS: Chuck.. I suspect your joking about the "Shock & Awe" technique.. ![]()
__________________
Home of The Original CORSESuperleggera #01 MV F4 Corse Superleggera # 01 Ducati 1098R ELR 1068cc EMAIL : john@jandrdasilva.co.uk “Life is a waste of time, and time is a waste of life. Get wasted all the time, and you'll have the time of your life!”.... |
#10 |
King of Bling
Huh, huhhuhuh .. Joe.. You said "Insertion" .... Heh, henh, henh, henh!. Huh, huhhuhuh .. Insertion is coool !... Heh, henh, henh, henh!. .
__________________
