Wheel compatibility - MVAgusta.net
log in
Forum
Go Back   MVAgusta.net > Hands On > Customizing
Thread Tools Display Modes
Old 12-31-2012, 09:21 PM   #1
bikefalcon1
No MVs in the Registry
bikefalcon1's Avatar
Default Wheel compatibility
Will wheels from earlier F4s fit on newer(2012) F4?
bikefalcon1 is offline   Reply With Quote
Old 12-31-2012, 11:49 PM   #2
Donsy
MV in the Registry:
[F4 1000 R]
Default
Yes, depending on which wheels you are reffering too, you might need the axle spacers for some at the front. The rear is the same on all.
__________________
Manuals are here - http://www.teamdouble3racing.com/manuals
Donsy is offline   Reply With Quote
Old 01-01-2013, 02:58 AM   #3
haupti
haupti's Avatar
Default
All pre 2010 bikes used larger front wheel bearings. The early F4 750 and 1000S as the Brutale 750, 910.., basically all with Showa forks, had larger spindles which fitted to the larger wheel bearings. Starting with the R or 312R models MV used a 25mm spindle and bridged the gap to the larger bearings with spacers. The 2010+ bikes have wheels with 25mm bearings which fit directly to the spindle. If You go for the earlier Star wheels, Brembo / Marchesini forged or ultra light forged in Magnesium or Aluminum, all can be fit to Your 2010+ with the spindle and spacers of the 312R, for an example.
As Donsy said the rear wheels fit on everything build by MV in between 1998 and 2013 without any trouble.
haupti is offline   Reply With Quote
Old 01-01-2013, 04:30 AM   #4
Donsy
MV in the Registry:
[F4 1000 R]
Default
Love your work Ralph, I was hoping you would jump on it. You just have a way with words and those front wheels.......
__________________
Old 01-01-2013, 01:06 PM   #5
bikefalcon1
Default
Thanks guys for the info. I am considering going to forged wheels to replace the cast ones on my 2012 F4R. Lusting after some BST carbons but budget not there at present. MV forum is the best.
Old 01-02-2013, 11:12 PM   #6
theknurl
theknurl's Avatar
Wink
all MV front wheels '99-'09 use a 6907-2RS....35 X 55 X 9 bearing
when they went to the RAC 50 forks the axle got smaller, but the wheels used the same bearings with a spacer
'10+ they're using the RAC 50s with the small axle, i don't know the bearing size...but i'm betting its the same
i have parts books for the <'10 bikes nothing later
my '05 F4 has radial bottoms on the Marzocchis for 310mm discs with the big axle and no spacers
__________________
The Forum Curmudgeon
i'm not PC either
Noel-theknurl
ph. 310-540-4823 PST, GMT -8
email, PayPal; theknurl@yahoo.com
Skype; theknurl
theknurl is online now   Reply With Quote
Old 01-09-2013, 11:24 AM   #7
cristogrr
MV in the Registry:
[F3]
cristogrr's Avatar
Default
Is it possible to put a larger rear wheel from a F4 to a F3?
6" instead of 5,5"
__________________
If you are confortable with your bike, you are not fast enough ! John Kocinski
cristogrr is offline   Reply With Quote
Old 01-09-2013, 02:29 PM   #8
JerseyBrut
JerseyBrut's Avatar
Default
You mean some like these....
If you are interested check the for sale section, they are worth it!
Dave
__________________
Stuck on a rock off the coast of France
JerseyBrut is offline   Reply With Quote
Old 01-09-2013, 09:48 PM   #9
bikefalcon1
Default
Ok, marchesini forged front wheel to fit on the 2012 F4r. Anyone have the spacers/axle I need laying around?
Old 01-10-2013, 05:36 AM   #10
Default
Probably.
__________________
ΜΟΛΩΝ ΛΑΒΕ
CAG is online now   Reply With Quote
vB code is On
Forum Jump
