Help: 2005 F4 Battery Issue - MVAgusta.net
log in
Forum
Go Back   MVAgusta.net > Models > F4
Thread Tools Display Modes
Old 12-24-2012, 06:38 AM   #1
Hdin08
MV in the Registry:
[F4 1000]
Default Help: 2005 F4 Battery Issue
I just return back from a six month deployment...upon returning the battery was dead...I went and purchased a brand new battery check it at the store to make sure it was fully charged too...plugged it up and the bike started right up...took it out for about a 10 miles ride and while ride the battery light came on and eventually the bike completely died...I jump started it and it turn over but after taking the charge off the bike died again...please help...thanks in advance.
Hdin08 is offline   Reply With Quote
Old 12-24-2012, 07:15 AM   #2
silentservice703
Location: In Duxbury, MA, USA with Lee and Patty in my heart.
Send a message via AIM to silentservice703 Send a message via Yahoo to silentservice703 Send a message via Skype™ to silentservice703
Default
Search this forum for "bike won't start" and "battery".
There is a ton of information.
Most people in this predicament find that they reversed the polarity when putting the new battery in service and have done some fuse and/or diode damage.
__________________
Keep your words soft and sweet...for somday you shall eat them!
A government that robs Peter to pay Paul
can always depend upon the support of Paul.
-- George Bernard Shaw
silentservice703 is offline   Reply With Quote
Old 12-24-2012, 07:21 AM   #3
MVBERT
No MVs in the Registry
Default
The Yuasa battery I fitted to my F4 750 was checked before it was sent out to me that it could hold enough charge, then after I fitted it I put it on a trickle charger over night. This is the sealed factory acid type. Once a bike is running as long as the alternator is functioning it should be fine irrespective of the batteries charged state shouldn't it?
Did you reconnect all the leads up to the battery, with my alarm etc I think each terminal on my batt has at least 3 leads?
MVBERT is offline   Reply With Quote
Old 12-24-2012, 07:23 AM   #4
silentservice703
Default
MVBert, in your case, probably. In the case of a defunct battery, no. Batteries become massive loads on the system when they fail.
__________________
Old 12-25-2012, 04:18 PM   #5
Tony F
Tony F's Avatar
Default
What brand of battery did you fit? Are all the leads are correctly connected to the battery? If so, have the battery tested with a load tester.
Tony F is offline   Reply With Quote
Old 12-25-2012, 09:22 PM   #6
Donsy
MV in the Registry:
[F4 1000 R]
Default
My money is on the battery going in wrong.
__________________
Manuals are here - http://www.teamdouble3racing.com/manuals
Donsy is offline   Reply With Quote
Old 12-25-2012, 09:50 PM   #7
gotojoe
MV in the Registry:
[F4 1000 R]
gotojoe's Avatar
Default
U need to check the battery voltage. You may have bought the Friday afternoon one
gotojoe is online now   Reply With Quote
Old 03-02-2013, 08:38 PM   #8
Hdin08
MV in the Registry:
[F4 1000]
Default
Sorry got deployed again...the battery was a interstate all leads were correct it was completely dead when I came back this time too...put another new one in and the battery light already came on when I turn it on.
Old 03-02-2013, 08:56 PM   #9
Donsy
MV in the Registry:
[F4 1000 R]
Smile
Please show us a picture of your battery connected in the bike.
And did you check the fuses?
Have you looked at the service manuals mate - http://www.teamdouble3racing.com/manuals.php .
__________________
Old 03-02-2013, 09:26 PM   #10
Hdin08
MV in the Registry:
[F4 1000]
Default
Just was looking through the owners manuals didnt see much in there to help...uploading some pictures know the negative ones are hard to see if want I can take the seat off and get better ones..
vB code is On
Forum Jump
