# New Mesh for Fairings - MVAgusta.net
log in
Forum
Go Back   MVAgusta.net > Models > F4 - 1st Gen. 1998-2009
Register FAQ Members List
Thread Tools Display Modes
Old 12-18-2012, 05:04 PM   #1
hkrauss
Member
No MVs in the Registry
Default New Mesh for Fairings
I read about a billion posts yesterday and in one of them someone mentioned that there is a wire 'mesh' with larger holes that is available to replace the stock stuff in the fairings that will allow more air to escape and help with the overheating. I can't find any information on it, and now I can't even find the post that mentioned it !! I've got an '08 F4 312R and its got the 2 Muzzy fans, an auxiliary fan, all three fane are on an over-ride switch so I can turn them on at will, coolant is distilled water and water wetter. All the above has helped a lot, but temp still gets to blinking at me on occasion. Only way I can reliably get the thing not to overheat in the Texas summer is if I remove the fairings. Thought I'd give the new mesh a try. Any info would be helpful. Thanks.
__________________
The older I get ... the faster I was ...
hkrauss is offline   Reply With Quote
Old 12-18-2012, 05:20 PM   #2
R1andrew
MV in the Registry:
[F4 1000 R]
[F4 R]
R1andrew's Avatar
Default
I think you would have to make your own.
R1andrew is offline   Reply With Quote
Old 12-18-2012, 05:28 PM   #3
Rob_b
MV in the Registry:
[F4 1000 R]
Rob_b's Avatar
Default
Maybe these can help
http://catalystracingcomposites.com/...mv-agusta.html
Rob_b is offline   Reply With Quote
Old 12-18-2012, 07:33 PM   #4
cooper3309
MV in the Registry:
[F4S 750]
cooper3309's Avatar
Default
http://www.mvagusta.net/forum/showthread.php?t=30148
I made my own mesh kit.
__________________
Take off your pants and jacket
01 750S W/1000R engine
01 Ducati 748 W/853 kit
03 Yamaha R1 (SOLD)
01 Kawasaki KX 125
88 Yamaha YSR 50
01 Yamaha R6
03 Suzuki DRZ pitbike
1982 Honda 110 atc
Yamaha PW50
1978 Honda 90 atc
2011 Yamaha Grizzly 700
2008 Yamaha Raptor 660
1975 Kawasaki G5 100
cooper3309 is offline   Reply With Quote
Old 12-18-2012, 09:36 PM   #5
haupti
haupti's Avatar
Default
Wire mesh with larger holes for better air flow ? Skip the mesh at all and You will have the maximum air flow possible.
haupti is offline   Reply With Quote
Old 12-18-2012, 09:40 PM   #6
Default
It's not the air flow in, it's the air flow out. That's why removing the fairings solves your problem. You've done all you can to suck as much air in, but nothing to get it out. On the early F4s there was no mesh on the exit areas. That came later. I think even if you removed the mesh, it would still not be enough. Some forum members have modified the side fairings for increased air flow. I believe the link that was posted will show you what they look like.
CAG is offline   Reply With Quote
Old 12-18-2012, 11:16 PM   #7
hkrauss
Member
Default
Any advice on how to remove the stock mesh without tearing up the plastic?
__________________
Old 12-19-2012, 07:00 AM   #8
Default
It is attached with some very sticky double back tape. Peel it away with a razor blade then clean any residue with laquer thinner. I don't have any panels here to look at, none of mine have the mesh, but that's how I remember it.
Old 12-20-2012, 03:34 PM   #9
hkrauss
Member
Default
I'll give it a try. If removing the mesh can bring temp down 3-4 degrees at top end it will help. Thanks for your help.
__________________
Old 12-20-2012, 03:42 PM   #10
MV BOY
MV BOY's Avatar
Default
My mesh isn't attached with double sided sticky tape but a hot silicone glue which will also cut away with a knife. I'm not sure what to use to refit them as intend removing mine when I have my panels painted....
.....and I think the fairings look ugly with no mesh fitted, just my opinion
MV BOY is offline   Reply With Quote
vB code is On
Forum Jump
Powered by vBadvanced CMPS v3.2.3
Powered by vBulletin. Copyright 2000-2010 Jelsoft Enterprises Limited.
