Fitting a hugger. - MVAgusta.net
log in
Forum
Thread Tools Display Modes
Old 12-18-2012, 03:09 PM   #1
jpc
Member
No MVs in the Registry
Default Fitting a hugger.
I picked up my new 2012 F4R and have a rear hugger to fit, has anyone installed one of these, what screws do I need, I don't want to remove the back wheel to do it, any tips?
jpc is offline   Reply With Quote
Old 12-18-2012, 04:56 PM   #2
badboy
Default
Hi and congratulation. Yes you need to remove the rear wheel and you need 3rubber bushing, 3 washers and 3 screws. You should find the parts at any Mv dealer.
badboy is offline   Reply With Quote
Old 12-18-2012, 05:53 PM   #3
Donsy
MV in the Registry:
[F4 1000 R]
Default
Not too sure on the size for the Y10+ bikes. But usualy you would need the 3 x 5mm wellnuts and capped screws, you can get these from pro-bolt and forum sponsors as well as many places on eBay.
http://www.probolt-australia.com/wor...bber-nuts.html
http://www.desmoparts.com/products/p...bber-well-nuts
__________________
Manuals are here - http://www.teamdouble3racing.com/manuals
Donsy is offline   Reply With Quote
Old 12-19-2012, 12:39 AM   #4
Adana
Member
Adana's Avatar
Default
Its absolutely much easier to do if you remove the rear wheel but from personal experience I can tell you that if you have a socket drive with a universal joint and some patience its possible to fit a hugger with the wheel in place.
Adana is offline   Reply With Quote
Old 12-19-2012, 04:26 AM   #5
gotojoe
MV in the Registry:
[F4 1000 R]
gotojoe's Avatar
Default
Congratulations on your new bike And fitting a hugger is a great idea..
But, why not just take the wheel off?
It's good to take a wheel off as it means it is unlikely to be a big problem when you eventually "have" to take it off. You can check the threads are correctly greased and that there is no corrosion on the mating faces of wheel to spindle.... You can also check the hub bearing smoothness of rotation while you're there.. Always useful..
It's just one nut...turn clockwise..take wheel off...
Is the Y10 swing arm predrilled to take the hugger wellnuts ?
Badboy..."You should find the parts at any Mv dealer."..... They will put them on special order from Italy and you will see them maybe in six months time ...
joe
gotojoe is offline   Reply With Quote
Old 12-19-2012, 06:13 AM   #6
lurch
lurch's Avatar
Default
I bought this before I found the forum - http://www.ebay.co.uk/itm/MV-Agusta-...item4aa92a8880
There are probably cheaper options but this was easy and cheap enough IMO
lurch is offline   Reply With Quote
Old 12-19-2012, 08:16 AM   #7
Adana
Member
Adana's Avatar
Default
On the MY12 F4 the swing arm is indeed pre-drilled to take a hugger.
Old 12-19-2012, 01:24 PM   #8
jpc
Member
Default
Thanks all sorted now.
I need to leave the back wheel in as I don't yet have a stand for it.
vB code is On
HTML code is On
Forum Jump
