#1 |
Member
No MVs in the Registry Join Date: Aug 2011
At 659 miles:
1 oil filter $11.81 1 washer, oil drain $1.09 1 PWR SYN 4T 10W60 100% Syn 4LTR $81.00 Labor 1.1 hrs., $100.00 Oil filter change, Air tires, adj / wax chain, lube pivots, check lights, brakes, tires, fliuds, clean, test ride. Shop supplies $3.00 Waste oil disposal $3.00 ---------------------------------------------------------------------------------- Total $199.90 Pjk |
| Sponsored Links | |
Advertisement |
#2 |
It would help if we knew where you lived Peter. Are we talking $199 Fijian Dollars? Aussie or the likely candidate US of A? In which case my equiv. first service at US$155 is looking good.
Anyway, well done on a good purchase and time to clock up more miles. I'm at 6,000 miles now. Oh the pain, another service and rear tire coming up soon right on Christmas. Santa, need cash, where are you...
__________________
Happiness is a means of travel. Not a destination |
#3 |
Member
Yeah. I forgot to add that I thought it was a bargain. The only problem was a buzzy left mirror which they are replacing clomlete under warrentee. I've watched off-an-on reading the various problems people have had and it's a shame, but mine has run great since day One. No mechanical, starting, electrical, or finish problems which is pretty good for a first run bike.
Pjk in the USA |
#4 |
I assume you bike has the new map?
__________________
Don't make excuses, Make it happen 05 F4 07 SENNA (261/300) 13 F3 04 Ducati 749s (Track Project) 06 CBR600RR (Track Project II) 08 Aprilia RSV (Rest In Pieces) |
#5 |
![]() Join Date: Aug 2009
According to the workshop manual you should be using 10W40. Is there a reason why they used a thicker 10W60?
#6 |
Member
I finally got a response from the dealer. They are using 10W50 in the F3 and mine has the updated ECU. I've had it out a couple of times since getting it back from the service and it runs great, but it ran great before.
Pjk |
