#1 |
Took the hub out of my 1090 today, its done 13,000 miles and it seems fine but thinking of replacing of the bearings and seals whilst its out.
Does anyone know the seal and bearing(s) size/designation? thanks
__________________
1090RR Benelli TNT1130 Honda CB125(180)S Pushbike Last edited by billywhizzz : 12-08-2012 at 01:36 PM. |
| Sponsored Links | |
Advertisement |
#2 |
![]() Join Date: Nov 2009
Hey Shaun,
I have a 2010 Hub here. There are two needle roller bearings, one wheel side and one sprocket side. They are same size as the needle roller ( only one ) in pre 2010 Hub and aren't known to fail. size 5520 There is also a single row deep groove ball bearing size 810 on the wheel side of the 2010 hub. If you want I can take my hub to Hayleys tomorrow who supply industrial bearings and ask them for a price for a FAG or SKF quality bearing for the 810.. Unless you have had some kind of failure in the hub I would check, clean and regrease the needle rollers. I can't imagine there would be any issue with them as even in the old style hubs they weren't known to fail. he seal on the sprocket side is well protected and I would simply prise it out carefully and reuse it. As for removing the bearings they can be drifted out after removing the Seager ring. I usually give my bearing installation work to Henry who has all the kit and kaboodle to do it and pay him a tenner ; ). joe Last edited by gotojoe : 12-09-2012 at 09:24 AM. |
#3 |
hello Joe, thanks for this, since posting read a few other threads and plenty by you on the subject and removed the thrust bearing today, de-greased and re-greased the needle rollers, all are good so will leave the bearings until next year. Shaun
__________________
1090RR Benelli TNT1130 Honda CB125(180)S Pushbike |
#4 |
Top man Shaun..I'll let you know the price and availability of the 810 ball bearing when I get the info.
good work..How did you pull the bearing out ? joe |
#5 |
hello Joe, the thrust bearing isn't an interference fit, just a light tap and its out after removing the Seager ring, the needle rollers are however much tighter so decided not to try and remove them. Not sure if any of the 3 brg hubs have failed but if they have my guess is the thrust bearing is the weak point. Shaun
__________________
#6 | |
From everything I have read I can't see any issue whatsoever with your needle rollers.. atb joe |
#7 |
For those who have asked these are the parts needed for the 2010 + hub
INA G55x63x5 Oil seal x3 HK5520 Drawn Cup Type Needle Roller Bearing With Two Open Ends 55x63x20mm x 2 SKF 618102RS1 Sealed Deep Groove Ball Bearing 50x65x7mm x 1 Typical designations as above. Shaun
__________________
#8 |
Shaun,thanks for the info.I have recorded the part numbers for future reference.
__________________
![]() Mitch The Hub Man Work.Email & Paypal. tweedcitytruck@onestream.com.au Work Phone (+61)0755244655 |
#9 | |
#10 | |
.....nice way to 'fix' the problem![]() just remember folks..... MV puts the seals in backwards ![]() the writing on the seal goes AWAY from the bearing the needle bearing basically never fail, i've sold 2 vs almost 200 3810-2RS bearings and that was because of seal failure i'll find the 61810-2RS too, it will be in my sticky on the UK Forum
__________________
The Forum Curmudgeon i'm not PC either ![]() Noel-theknurl ph. 310-540-4823 PST, GMT -8 email, PayPal; theknurl@yahoo.com Skype; theknurl |
