#1 |
I have 55 gal. of 100% food grade propylene glycol. It is new and unused. It contains corrosion inhibitors. Is there any reason I can not use it as a coolant if I dilute it to the proper consentration for my climate?
Thanks Mike |
| Sponsored Links | |
Advertisement |
#2 | |
No MVs in the Registry Join Date: Feb 2012
![]() To answer your question though probably not but I don't know the proper concentrations myself - don't confuse it with ethylene glycol as they have different physical and thermodynamic properties (as well as chemical). |
#3 |
Yes...propolyne glycol is used in "environmentally" friendly auto antifreeze. 50/50 mix with deionized water will work. Won't kill the dogs if you leave a puddle. Offers decent cooling properties and won't freeze when temps get cold.
I have a gallon of Prestone's auto version. Thought it might be ok for track use, but turns out it is still slippery stuff and not allowed in track bike radiators. So mix it up and enjoy your "green" coolant.
__________________
I used to be fast....now I just dream about it. ![]() '08 910R, '04 F4 SPR #275 Track Bike, YSR50 restoration project, '71 CB100, '78 ATC70 |
#4 |
King of Bling
There are 3 main types of antifreeze. Ethylene Glycol, Propylene Glycol, and HOAT antifreeze. Nowadays EG isn't used or readly available in the larger UK outlets because of tightening of eviromental laws.
However, PG is fully biodegradable. There have been issues with certain brands of PG and I remember reading somewhere that Honda and General motors had problems with the cars after using a certain brand of antifreeze. I think it might have been Dexcool. .
__________________
Home of The Original CORSESuperleggera #01 MV F4 Corse Superleggera # 01 Ducati 1098R ELR 1068cc EMAIL : john@jandrdasilva.co.uk “Life is a waste of time, and time is a waste of life. Get wasted all the time, and you'll have the time of your life!”.... |
#5 |
On the subject of FOOD GRADE antifreeze...check your pickle jars, your laxatives, your (insert ingestible here) many of them contain Propylene Glycol.
__________________
Keep your words soft and sweet...for somday you shall eat them! A government that robs Peter to pay Paul can always depend upon the support of Paul. -- George Bernard Shaw |
