| Sponsored Links | |
Advertisement |
#2 |
This link may help you and the paint codes will also be in the owners manual.
http://mvfaq.blogspot.co.nz/2005/11/paint-codes.html
__________________
It ain't what you ride, it's the way you ride it. |
#3 |
Where are you located?
#4 |
Contact Color Rite.......they are the industry supplier for motorcycle OEM paint. They have MV red and silver available. Touch up sticks, aerosol cans and pints for professional spray.
__________________
I used to be fast....now I just dream about it. ![]() '08 910R, '04 F4 SPR #275 Track Bike, YSR50 restoration project, '71 CB100, '78 ATC70 |
#5 |
Forget the Colorite paint: I ordered the silver and it's not even a close match to my 2007 F4R silver. It's quite a bit darker silver. Shame I had to pay about $165 to find out!!
Also, forget the Chromabase color mentioned somewhere here. I spent another $100 at the local auto paint store and while the shade is closer than the Colorite paint, it has too much metal flake in it. Another bust. However, I just got a pint of PPG silver (the one for the older Ferraris that was discussed) and so far it seems a much closer match. The shade is very close and it has a fine metallic that's a lot closer to the OEM paint. I'll be spraying my belly fairing tomorrow so can give a definitive answer at that time. Eric |
#6 |
![]() No MVs in the Registry Join Date: Oct 2007
I always take a sample panel to my paint guy and he mixes it to match. Can't tell the difference. You can get it in either single step catalyzed urethane or base/clear coat.
__________________
I got mine. Boy do I ever got mine. |
#7 |
So true Lee....most really good auto paint shops have the ability to make paint that matches an existing panel.
When I had some repairs done on Gina several years back I asked the paint guy if he wanted the color codes. His answer was "we don't need those, we make our own paint." The pearl white he made was perfect.
__________________
#8 |
In 6 years methinks the original paint is going to fade. A lot. I just received a NOS mid fairing and marked 2005 (my model year) and it is way off from my bellypan fairing. I'd say taking the panel and getting it color matched would be the way to go. And for the diy shooter, here you go.
__________________
Art |
#9 |
I took my 2007 F4R belly fairing to the auto paint shop to see if they could use their scanner to get the corrrect color. From what I could tell, their PPG tool takes scans from at least 5 spots and averages them for the mix. The final value is rated on a 0-30 point scale, with 0 being a perfect match and 30 being not so good.
My mint fairing came in at an 11 which the paint guy said is a gamble for panels that sit adjacent to one another. Unfortunately, my paint shop doesn't do color matching so I'd have to go to a custom shop and hope for the best. |
#10 | |
People really underestimate the power of wear and the sun for color fade. I tried to buy a tan interior part for one of my cars from the factory and when it arrived I ended up having to toss it out because it did not match at all. It was the same color code minus several years of fading and wear. A used part matched much better. Last edited by rchase : 12-06-2012 at 05:25 PM. |
