#1 |
Would anybody trust a well qualified tech that has not much MV experience to check and/or adjust valve clearance on 2007 Brutale? Otherwise I drive 350 mi. to nearest MV dealer
| Sponsored Links | |
Advertisement |
#2 |
Check, yes, adjust, not so sure about that.
In fact checking the clearances is something you can do yourself at home. It's not that difficult at all. All you need is some basic tools, a new rubber valve cover gasket, some gasket sealer and some metric feeler gauges within the range specified in the service manual. It is quite likely that you'll find that they are in spec and you'll have learned a new skill.
__________________
It ain't what you ride, it's the way you ride it. |
#3 |
How many km's on your Brutale? I would agree with Mr Castle.
Happily trust them to check, could do this yourself if you feel thus inclined. As far as adjustment goes, probably very little chance any adjustment will be required but if there is it would help to have someone who you definitely trust as knowledgeable with this stuff (Don't want just any Bloggs messing with ya valves). Cheers
__________________
"You live more for five minutes going fast on a bike than other people do in all their life" #58
#4 |
Thanks. I've managed to change hub bearings with good results. I think I'll re-read all I'vlearned on another thread and go for it. Thanks again!
#5 |
Adjustment is similar procedure to any shim under bucket bike engine. An experienced tech with good skills could handle it regardless of brand background. Providing the technical manual info on cam timing is essential.
Bear in mind that many shim under bucket valve trains do not even call for inspection until 16,000 miles or more....and most need no shim changes even then. My 910R has 21,000 miles now and all the valves were still in clearance spec at last check.
__________________
I used to be fast....now I just dream about it. ![]() '08 910R, '04 F4 SPR #275 Track Bike, YSR50 restoration project, '71 CB100, '78 ATC70 |
#6 |
arizona brutale;
i wouldn't bother checking them......i know what the book says 7,500mi/12,000km i'm a little over 16k mi so they "should" have been checked twice.....did I ? nope but it says to change the plugs then too.....and look what cars get out of fine wire plugs Aprilia used to say even check at 600mi/1,000km my RSVR is at 30k mi/50k km and haven't moved a bit....i'll peek again at 50k mi/80k km.....my friend Paul in J'town was at 80k mi/130k km and they were fine Dave why spend the money for a new gasket? they want you to use sealer on it anyway! glue the whole damn thing, not just the half moons you can get shim assortments from Hot Cams, you will need the 7.48mm ones....don't use shims under 1.60mm ![]()
__________________
The Forum Curmudgeon i'm not PC either ![]() Noel-theknurl ph. 310-540-4823 PST, GMT -8 email, PayPal; theknurl@yahoo.com Skype; theknurl |
#7 | |
I'm batting less than 50% on cleaning the old gasket and avoiding a leaky little leak. So, you want me to send you my old gaskets? ![]() See what I did with the red writing there, Noel? I know you love that red writing. ![]() Love you. Dave.
__________________
#8 | |
can i fix it? yes, will i use a new gasket? no! i will use Permatex RTV Silicone; http://www.permatex.com/products/pro...-gasket-detail will it leak again NO, trust me, i've been doing this a long time re; cleaning old gasket material..... i use lacquer thinner or acetone, if they don't remove it, it can stay my Aprilia RSVR valve cover gaskets started pouring oil at ~13k mi, both cylinders......at 30k mi the same gaskets are on there....glued on there with high temp silicone......they DO NOT leak apparently MV got their cover gaskets from the same supplier as Aprilia they shrink on the exhaust side and leak do the F4 covers leak? a lot of the time are they flat? no.....is mine? yes, i flattened it with one of these; http://vintagemachinery.org/photoind...es/10064-A.jpg its glued on too my '67 T-100R didn't leak, i fixed that.....so why would i let my MVs leak?
__________________
#9 |
![]() Join Date: Nov 2009
"arizona brutale;
i wouldn't bother checking them......i know what the book says 7,500mi/12,000km i'm a little over 16k mi so they "should" have been checked twice.....did I ? nope" I asked a little while back if any of us after having the valves checked had to actually adjust them. The answers came back as an emphatic "no" The only one I remember was a bike that came out of the factory with a gross error in clearance. I would personally have the valves checked once at first recomended interval and then go and worry about other things... However if the bike is in stripped down condition then it would make perfect sense to check the valves at that convenient moment. I'd be interested in Donsy's experience on this subject in the racing field.... Just my opinion ..but I do wonder if we get stuck in a bit of a time warp on this. Now my old airhead beemer..I check the valves on that twice a year usually... joe |
#10 |
![]() Join Date: Aug 2009
You just put me on the spot didn't you
.No problem mate, when I do a bike that has only done 8-12000km, I re-use the gasket, but I always keep one spare just in case. I find as the bikes get past that age/milage, the gaskets seem to get harder and might have crack's in them, but keep in mind, over here the bikes run a lot hotter than up your way. I have never replaced the gaskets on my motors cam covers, they are now going towards 10 000km each, and I will check valve's again on my 07 #2 motor as I just threw her down the road and she was spinning on the 13 700rpm(set in 3rd gear) rev limiter for a while before cutting out. I don't have gasket's on any other parts of my motors (sump, clutch ...etc) When I help someone else on their bikes, I tend to play safe as some of these guys come a long way to get their bikes serviced. When I install a new gasket, I use sealnt all the way round though. |
