Help! - MVAgusta.net
log in
Forum
Go Back   MVAgusta.net > Models > F4
Thread Tools Display Modes
Old 11-30-2012, 04:48 PM   #1
billas f4
billas f4's Avatar
Default Help with fuse please. urgent
Finally decided to ride to work today. It is about a 10 mile ride. A quarter mile to work I noticed that I had no rear brakes. Thank God we use 90% front brakes. As soon as I got to work the bike leaked what looks like almost all of the coolant. I took out the right fairing and looked at the fuse box. Since my Workshop Manual is at home, which of the 7 15amp blue fuses is for the cooling fan? I'm thinking and hoping that it is just the fuse and nothing else. Thanks in advance for your help.
__________________
2003 749S
2008 F4 R312
billas f4 is offline   Reply With Quote
Old 11-30-2012, 05:18 PM   #2
billas f4
billas f4's Avatar
Default Help!
Can someone help me with this? Thanks. http://www.mvagusta.net/forum/showth...620#post571620
__________________
2003 749S
2008 F4 R312
Old 11-30-2012, 06:40 PM   #3
mitchy
mitchy's Avatar
Send a message via Skype™ to mitchy
Default
I own a 1078 F4, on the R/H side of the bike the fan fuse is second last fuse going from left to right.Hopefully your model is the same.Leave the panel off and start the bike and see if the fans kick in at around 97 degrees C.Sounds to me like there is air trapped in the cooling system or coolant level is above the min mark in the coolant bottle.Common problem with MVs if coolant is spewing out.Hope I am of some help.
__________________
Mitch
The Hub Man
Work.Email & Paypal.
tweedcitytruck@onestream.com.au
Work Phone (+61)0755244655
mitchy is online now   Reply With Quote
Old 11-30-2012, 08:16 PM   #4
R1andrew
MV in the Registry:
[F4 1000 R]
R1andrew's Avatar
Default
What more info can you give us?
If your bike is over filled on fluids it will leak or if air is in the system. Like said start her up and let her get up to 210. You can fill the fans kick on and blow hot air out of the fairing. Easy to take the fairing off and see. This would also have nothing to do with no rear brake. I hardly ever use my rear brake. On mine I could not lock up the rear wheel even if I tried. Let me track down my book and I will let you know which fuse runs the fans.
R1andrew is online now   Reply With Quote
Old 11-30-2012, 08:21 PM   #5
R1andrew
MV in the Registry:
[F4 1000 R]
R1andrew's Avatar
Default
Fan fuse is in the manual labeled E-5. It is also the second one from the spare. I have a 1000R but it should be the same. Hope this helps.
Old 11-30-2012, 09:47 PM   #6
billas f4
billas f4's Avatar
Default
Thanks for the help let me try this now. Its a bit hard to remove.
__________________
2003 749S
2008 F4 R312
Old 11-30-2012, 09:59 PM   #7
billas f4
billas f4's Avatar
Default
Can't remove the fuse!!!!! Aghh!!! Is it just a stright pull out?
__________________
2003 749S
2008 F4 R312
Old 11-30-2012, 10:04 PM   #8
billas f4
billas f4's Avatar
Default
Lost rear brake because it ran too hot that the it boiled the fluid. I am very surprised it did not shut off when I saw about 260 on the temp guage.
I put coolant again up to the level of the reserve tank and started her up run until 245 with fairings off. The fan did not kick in so I had to shut the bike and fluid came out again.
__________________
2003 749S
2008 F4 R312
Old 11-30-2012, 10:05 PM   #9
billas f4
billas f4's Avatar
Default
Do I just pull the fuse out like normal? Can't pull it out.
__________________
2003 749S
2008 F4 R312
Old 11-30-2012, 10:34 PM   #10
billas f4
billas f4's Avatar
Default
__________________
2003 749S
2008 F4 R312
vB code is On
Forum Jump
