#1 |
No MVs in the Registry Join Date: Jul 2011
Gentleman,
After washing my bike last weekend, I was thinking to warm up my MY10 F4 this morning. I press the engine start, it crank but failed to start the engine. After that, suddendly the temperature gauges on tach is increasing while bike never start. Then after several time tried, The bike was on, however the fan is running and temperature gauge never drop. Engine still cold but the fan is running and temperature gauges always at full gauges. Can you advise what is wrong with my bike? What should I do? I hope something little like shortcircuit. No MV Agusta dealer in my country. (But there will be on early next year) |
| Sponsored Links | |
Advertisement |
#2 |
Did you use compressed air on all electrical connectors after washing? Have you checked for any blown fuses? Just a guess,might be time for a battery.
__________________
![]() Mitch The Hub Man Work.Email & Paypal. tweedcitytruck@onestream.com.au Work Phone (+61)0755244655 |
#3 |
Sounds like your water temp sensor (or connection to it) is bad or may have water in it. Run some compressed air through the connection like Mitch said and/or spray with some water displacing aerosol. See if that works.
Finally if you have a good digital multimeter, check the resistance of the sensor. Extract from workshop manual below: |
#4 |
Mitch,
Sean, thank you for your reply. I am not washed with compressed water. I also had checked all fuses, seems they are fine. Battery just replaced on June/July this year. I will check that water temp sensor as appointed and run some compressed air on it. |
#5 |
No MVs in the Registry Join Date: Apr 2010
Disconnect the battery and switch on bike and press start button to drain all the power wait for a few mins then connect battery back see it helps
Use control wash next time Italian bikes are not water proof
__________________
I feel the need, the need for corner speed! Rollen Artwork. --~~~~
#6 | |
Touch wood, I have never had a problem after washing and I don't use compressed air to dry, I run the bike for a while after washing till bike reaches temp and function check fans and all lights etc before shutting her off. Last edited by MV BOY : 12-19-2012 at 04:14 PM. |
#7 |
A silicone based polish and microfiber cloths do a lot better of a job of cleaning and don't cause electrical issues or rust. Unless your bike has massive amounts of dirt or mud you don't have to use water. Using a cover as well is a great way to keep your machine free of dust and pollen.
#8 |
Yes, unfortunately MV need one of these tags on every bike.
__________________
Art |
#9 |
Hmmm.....I have ridden my 910R in the rain, and washed it with a garden hose many times. No problems.
As many MVs as there are in the UK I would think water shouldn't be a problem, or none of them would ever run. My MV has high quality water proof electrical connectors of the same type as used on many other vehicles and boats. All that said, you can still get water in places it shouldn't be....on any bike....not just MVs. The temp gauge going up and fan running with cold engine tells me the temp sensor has failed on this bike.
__________________
I used to be fast....now I just dream about it. ![]() '08 910R, '04 F4 SPR #275 Track Bike, YSR50 restoration project, '71 CB100, '78 ATC70 |
#10 | |
And it's not just the electronics that make me not want to wet my MV. The bearings and and finishes don't seem to be hugely water friendly. I once saw an F4 that was stored outside and regularly rained on. It was covered in a coating of light corrosion everywhere. It probably would have cleaned up with metal polish but it looked awful. Cleaning it up likely would have required a complete disassembly. |
