Lightech Rearset - MVAgusta.net
log in
Forum
Go Back   MVAgusta.net > Models > F3
Thread Tools Display Modes
Old 11-20-2012, 05:58 PM   #1
7SinS
Member
No MVs in the Registry
7SinS's Avatar
Default Lightech Rearset
Hi there,
I am 5'10 having a problem staying on the bike without sliding back and forth during street ride. I have added a knee pad on the tank but since the slick looking design of the tank i found it tiring to keep my legs press against it during a long ride. I am looking for an aftermarket rearset that can raise my legs about 20mm so my knee can rest comfortably pressing the bottom lid of tank (where the pointy section that sticking out) to stop me sliding. I came across with this rearset during my hunt, fair price with decent quality, however, on the website it didn't mention any informaiton about the adjustablility (+/- ??mm). Just wondering is there anyone here have this fitted on their F3 or does anyone have it fitted on anyother bike that could give me a rough indication of the adjustablity compare to the stock rearset.
http://www.lightech.it/scheda.asp?cod=FTRMV002
Arnold
__________________
7SinS is offline   Reply With Quote
Old 12-04-2012, 11:16 PM   #2
corran
MV in the Registry:
[F3]
corran's Avatar
Default
I raised my rearset almost 50mm from stock. At 5'9" it ww tiring keeping my knees in the tank.
Mv Augusta now has a really cool aftermarket adjustable rearset. You can find it on the mvagusta.it site.
Corran
corran is offline   Reply With Quote
Old 02-09-2013, 07:15 AM   #3
7SinS
Member
7SinS's Avatar
Default
Just a quick notes on the Lightech Rearset to those who might be interested
After waiting for 2months and more, i have finally recieved my kits today from reactive.co.uk
It has a superb fnisihing and it gives a vy subtle and clean looks to the bike.
It have 24different position (2 track, 3 holes each, Left/Right pegs reverse position and up-side down postion)
the highest setting will allows you to raise about 20-25mm and slide back about 30-40mm.
I'm vy pleased on this purchase and i would highly recommend others.
One other thing that worth mentioning,
The gear shift lever is relocated and mounted on the bolts which uses to secure the bike stand.
However, there is no extended bolt to replace the original bolt,
If i use the original bolt from the bike with the stand, the bolt will shift out more than half of it length from the socket,
since it is the bolt that secure the bike stand, i am not sure is it strong enough to hold the bike without an extended bolt??
At this stage i am still waiting on the confirmation e-amil from Lightech and reactive.co.uk
But I have a feeling that this product might be desgined for track use only. Good news is the parts is possible to bolt on to the bike using an extended bolt with no clearance issue. So the worst case senario is you will have to source an extended bolt if you want to use it on the street.
P.S. The photos show on designcorse.co.uk aren't the F3 model, The F3 model allows you to bolt on the EAS directly.
Arnold
__________________
Old 02-09-2013, 09:08 AM   #4
ceepee
Default ceepee
hi, i had the same issue with the bolt extension you mention, got one made locally to myself(no good to you though I'm in the uk) however you just need to extend the bolts 10mm, i no longer have the image i took of this but i did send it to donsy one very informative site user now living in oz, he may well see this and post the pic or information to contact him is on many of this sites topics, i recall its donsy@teamdouble3racing.com if im correct, i fitted mine with no bother but my rear sets were from pp racing but had the same issues you raise.
ceepee is offline   Reply With Quote
Old 02-09-2013, 09:11 AM   #5
ceepee
Default ceepee
sorry i should have mentioned the bolts were extended 10mm as that was the thickness of the rear set bracket, so just measure the depth of yours and hey presto.
Old 02-09-2013, 09:24 AM   #6
7SinS
Member
7SinS's Avatar
Default
Thx Ceepee for the information.
I will check out the local fastener shops first,
hopefully i can find some useful replacement there.
__________________
Old 02-09-2013, 11:16 AM   #7
crash2much
MV in the Registry:
[Brutale CRC]
crash2much's Avatar
Default
These should work for you.
http://www.mvagusta.net/forum/showthread.php?t=51055
crash2much is offline   Reply With Quote
Old 02-10-2013, 08:07 AM   #8
ceepee
Default
you won't get a bolt off the shelf, its two sizes act as a retainer for the exhaust collector box, I've now found the image that you need , post your e mail address and i'll send you the pics.
Old 02-10-2013, 05:45 PM   #9
Donsy
MV in the Registry:
[F4 1000 R]
Smile Sorted
This the pic you where looking for ?
__________________
Manuals are here - http://www.teamdouble3racing.com/manuals
Donsy is online now   Reply With Quote
Old 02-11-2013, 07:03 AM   #10
7SinS
Member
7SinS's Avatar
Default
Thx all for the inforamtion.
Fortunately, Lightech have a different approach on mounting thier gear lever.
Lightech rearset only uses the unique looking bolt as a stoper to stop the mounting bracket rotating.
In order to keep the original bike stand, all i needed is a standard M10 x 35mm socket head screw where i did manage to found it from a local wearhouse for two dollar. =]
__________________
vB code is On
Forum Jump
