water pump hoses - MVAgusta.net
log in
Forum
Thread Tools Display Modes
Old 11-19-2012, 04:48 PM   #1
gotojoe
MV in the Registry:
[F4 1000 R]
gotojoe's Avatar
Default water pump hoses
I found this evening that to fit the clik R clip correctly to the rear waterpump hose ( outflow ) , it's necessary to pull the clutch slave and water pump off so that the clip can be fitted from the rear facing side. This is to ensure that the spring clip which protrudes won't be able to rub on the outer water pump hose. If u don't do this the hose can be rubbed through and burst..
An easy job once you work out that you can't do it without pulling those two parts...but I did find myself going off thos clik R clips...
gotojoe is online now   Reply With Quote
vB code is On
HTML code is On
Forum Jump
