# 910S how to adjust rear rebound damping - MVAgusta.net
log in
Forum
Go Back   MVAgusta.net > Model Range > Brutale B4
Register FAQ Members List
Thread Tools Display Modes
Old 11-18-2012, 05:26 PM   #1
claudiop
MV in the Registry:
[Brutale 910]
claudiop's Avatar
Default 910S how to adjust rear rebound damping
Hi
I've bought 2006 910S and found the suspension a little strange so decided to reset to Standard. All good till I got to the rear Rebound damping/Braking in extension adjustment. The photo in the manual shows a 'hidden' view behind/above the collector? I can't figure out how to get to the adjusment screw without removing anything. Any tips appreciated
__________________
Brutale 910S 2006, BMW R1150RT 2002
claudiop is offline   Reply With Quote
Old 11-18-2012, 07:15 PM   #2
theknurl
theknurl's Avatar
Wink ?
Claudio;
i'm assuming you have a Cat in the way....
have you tried an angle screwdriver?
http://www.forteforums.com/forums/at...srewdriver.jpg
__________________
Noel-theknurl
The Forum Curmudgeon
i'm not PC either
eat bacon, pork and pork sausage
ph. 310-414-7247 PST, GMT -8
email, PayPal; theknurl@yahoo.com
Skype; theknurl
theknurl is offline   Reply With Quote
Old 11-18-2012, 07:49 PM   #3
claudiop
MV in the Registry:
[Brutale 910]
claudiop's Avatar
Default
theknurl
yeah, the thing in the way as in the pic is that 'tank'-like thing referred to as "exhaust compensator" in the workshop manual. I don't have an angled screwdriver and can't see that I'd be able to get it in
thnx
__________________
Old 11-18-2012, 07:52 PM   #4
eddypro
eddypro's Avatar
Default
Yep get a long flat blade look between the cat and frame you will see it
eddypro is offline   Reply With Quote
Old 11-19-2012, 04:53 PM   #5
Deano
Deano's Avatar
Default
As eddypro said, a long thinish flat blade screwdriver. It can be done, look between the can at the bottom.
Deano
Deano is offline   Reply With Quote
Old 11-20-2012, 03:51 PM   #6
BG Wells
BG Wells's Avatar
Default
Claudio....would you get something like this in??..http://www.ebay.co.uk/itm/30781-Bran...item5d32eb9831
However I think eddy's suggestion is the answer
Brian.
BG Wells is offline   Reply With Quote
Old 11-20-2012, 08:28 PM   #7
theknurl
theknurl's Avatar
Wink ?
claudiop;
1st thing i did was get rid of the Cat (exhaust compensator).....
i didn't play with the shock yet because i'm installing one with a lighter spring and hydraulic preload adjuster.....
i have the Ohlins wrenches for the lock rings.....but i'm not a masochist..... way easier to use the one with the preload adjuster
__________________
Noel-theknurl
i'm not PC either
Skype; theknurl
Old 11-20-2012, 08:44 PM   #8
afeylad
MV in the Registry:
[Brutale S]
Send a message via AIM to afeylad
Default
Claudiop, as an Australian owner of a 06 910s I found the stock Sachs shock utterly abysmal, especially on our rough roads here in oz! In particular the rebound ability.. A shock rebuild which included a new spring and revalve helped the issue, but it was still not as good as I liked. If you can afford it buy a new shock ie; ohlins, nitron, maxton, hyper pro etc
afeylad is offline   Reply With Quote
Old 11-20-2012, 09:11 PM   #9
claudiop
MV in the Registry:
[Brutale 910]
claudiop's Avatar
Default
hey guys, sincere thanks for ur tips. This morning my son and I had another go with a thin flat screwdriver but for the life of us we struck out. I had the major 12,000km service and a dyno last week. I told the bike shop at the time to reset all of my suspension to factory spec; instead they did a good service/dyno and before tweaking the suspension I was told to ride the bike for a couple of weeks and then come back and they'll fine-tune anything I've got concerns with. Meh, I got pre-emptive and did the suspension reset myself, except for the rebound damping. I've done c.300km since the service and the bike is running much better. I've got a couple of minor issues along with the rebound dampening and I'll get the bike shop to look at it.
On the other hand, the suggestion of upgrading to Ohlins etc is good, but I'll have to save up a bit for that
many thanks again, cheers Claudio
__________________
Old 11-20-2012, 09:58 PM   #10
afeylad
MV in the Registry:
[Brutale S]
Default
Keep an eye out for 2nd hand shocks on eBay, here on the forum etc to nab a good deal.. Even after my shock rebuild I still had to have the rebound dampening on its lowest/slowest(wound anti-clockwise all the way) setting to get a somewhat comfortable ride out of it! It was the only way I could stop it from kicking my arse out of the seat a mid to large bumps..
vB code is On
Forum Jump
Powered by vBadvanced CMPS v3.2.3
Powered by vBulletin. Copyright 2000-2010 Jelsoft Enterprises Limited.
