Rear Brake fluid - MVAgusta.net
log in
Forum
Thread Tools Display Modes
Old 11-18-2012, 10:04 AM   #1
gotojoe
MV in the Registry:
[F4 1000 R]
gotojoe's Avatar
Default Rear Brake fluid
Rear brake fluid. Pedal getting low ?
There are concerns about the fluid in the reservoir getting hot and some owners have moved the reservoir away from the rear of the engine crank case.
Whilst it isn't a good thing for the fluid to become hot in the reservoir I doubt if it is the primary cause of the pedal getting low.
The reservoir acts as a header for the system and as the pads wear the level in the reservoir will become a little lower.
I don't believe that during the course of a ride out that the brake fluid in the reservoir " mixes" into the brake fluid in the master cylinder as there is no return line as such.
Therefore when during a ride out if my pedal should get low then this is most likely due to heating of the fluid in the MASTER cylinder which sits close to the exhaust pipes. The Master cylinder is not completely shielded from the heat down there and I believe this is the principle area that requires attention and not the reservoir.
I'm interested in other's opinions on this too : )
joe
gotojoe is offline   Reply With Quote
Old 11-18-2012, 10:09 AM   #2
Donsy
MV in the Registry:
[F4 1000 R]
Default
Yup
__________________
Manuals are here - http://www.teamdouble3racing.com/manuals
Donsy is online now   Reply With Quote
Old 11-18-2012, 10:34 AM   #3
MV BOY
MV BOY's Avatar
Default
I moved my reservoir under my seat and fitted fast road pads to cure my rear brake or lack of rear brake problem but that only helped after curing the problem.........check yr exhaust as mine had cracked round the joint blowing hot gases straight onto the master cylinder. Welded up with additional webbing and problem solved. I now have a rear brake helped by changing the pads and moving the reservoir. Hope this helps!
Sent from my iPhone using Motorcycle.com App
MV BOY is offline   Reply With Quote
Old 11-18-2012, 11:56 AM   #4
luizfto
MV in the Registry:
[F4 MY2010+]
luizfto's Avatar
Send a message via Skype™ to luizfto
Default
I have replaced original DOT 4 fluid by DOT 5.1.
Brake pedal still lowers, but much less, and rear brake is still operative after a hard ride:
http://www.mvagusta.net/forum/showth...hlight=DOT+5.1
luizfto is online now   Reply With Quote
Old 11-18-2012, 02:34 PM   #5
silentservice703
Location: In Duxbury, MA, USA with Lee and Patty in my heart.
Send a message via AIM to silentservice703 Send a message via Yahoo to silentservice703 Send a message via Skype™ to silentservice703
Default
I use that special "R" designated brake fluid for the "R"ear brake........
__________________
Keep your words soft and sweet...for somday you shall eat them!
A government that robs Peter to pay Paul
can always depend upon the support of Paul.
-- George Bernard Shaw
silentservice703 is offline   Reply With Quote
Old 11-18-2012, 03:25 PM   #6
Renaissance
No MVs in the Registry
Renaissance's Avatar
Default
agree with gotojoe and Donsy and luizfto
mentioned in other posts but I had my exhaust header heatshield replaced with an improved material (larger and thicker version provided by MV) which better shielded the partly exposed m/c in addition to using dot 5.1....problem solved.
Renaissance is offline   Reply With Quote
Old 11-18-2012, 04:35 PM   #7
mitchy
mitchy's Avatar
Send a message via Skype™ to mitchy
Default
Spot-on Joe,thats why I did this,and it helps.Name:  100_1060.jpg
__________________
Mitch
The Hub Man
Work.Email & Paypal.
tweedcitytruck@onestream.com.au
Work Phone (+61)0755244655
mitchy is online now   Reply With Quote
Old 11-19-2012, 04:41 AM   #8
gotojoe
MV in the Registry:
[F4 1000 R]
gotojoe's Avatar
Default
But where can I cook my bacon n eggs now ? ; )
vB code is On
HTML code is On
Forum Jump
