Fuel flow? - MVAgusta.net
log in
Forum
Thread Tools Display Modes
Old 11-15-2012, 09:42 AM   #1
CBBOO
Member
MV in the Registry:
[Brutale 910]
Default Fuel flow?
Hi!
Just replaced the female fuel fittings on my Brute.
Connected the males and just to be reasured everything was ok. I blew into the OUT and ofcource there were no resistance (the filter and pump is still dissconected).
But blowing in to the IN, there were a lot of resistance! I could not blow in at all. When trying to suck I can clearly taste fuel. But is it normal that there is that kind of resistance or is something blocked in there?
Cheers!
Magnus
__________________
I like Žem naked!
CBBOO is offline   Reply With Quote
Old 11-15-2012, 09:51 AM   #2
Donsy
MV in the Registry:
[F4 1000 R]
Default bhaha
Originally Posted by CBBOO View Post
Hi!
Cheers!
Magnus
Enough blowing and sucking brother. Connect it and start it
__________________
Manuals are here - http://www.teamdouble3racing.com/manuals
Donsy is offline   Reply With Quote
Old 11-15-2012, 10:05 AM   #3
CBBOO
Member
MV in the Registry:
[Brutale 910]
Default
Guess youre right Donsy.
Thing is I dont want to take it apart again..
I removed the screw inside the tank and did some blowing and the resistance was gone so I guess It all is like it should be...
I have replaced all internal hoses and filter and fittings, the question now is if I shall replace the last pair of fuellines or shall I keep em?
/M
__________________
I like Žem naked!
vB code is On
HTML code is On
Forum Jump
