more stress - clutch pushrod - MVAgusta.net
log in
Forum
Thread Tools Display Modes
Old 11-14-2012, 02:50 PM   #1
chay250
chay250's Avatar
Default more stress - clutch pushrod
whilst i seem to be carrying out a multitude of jobs on my 312r - renewing stem and hub bearings fixing oil leaks at the sump and gearbox cover - awaiting the return of my forks from maxton i thought i would search the forum for the best options on chain and sprocket sets and happened to come accross a post warning that taking the clutch pushrod out from the left side of the bike will result in having to remove the clutch - ugh more stress!!
looking in the engine manual(which i failed to do prior to removing the slave cylinder otherwise i would have known better) it says removing pushrod from left side of the bike may damage a seal - what seal? what do you guys recommend ? will i get away with leaving well alone will i have caused any damage.
chay250 is offline   Reply With Quote
Old 11-14-2012, 04:58 PM   #2
Donsy
MV in the Registry:
[F4 1000 R]
Default
Not quite sure why you want to remove the push rod? or did you remove the slave cylinder and pulled the rod out by accident. The 312 does not have the part that drops off on the clutch side as far as I can remember, so you should be okay to push the rod back in, hopefully the seals did not get damaged by the grooves on the rod.
__________________
Manuals are here - http://www.teamdouble3racing.com/manuals
Donsy is offline   Reply With Quote
Old 11-14-2012, 05:18 PM   #3
chay250
chay250's Avatar
Default
thanks dons - fingers crossed it will be ok then.
Old 11-15-2012, 03:40 AM   #4
gotojoe
MV in the Registry:
[F4 1000 R]
gotojoe's Avatar
Default
You'll be ok Colin..There's nothing to drop off at the clutch end of your model...It was much earlier bikes..Too early in the morning for me to look up but yours is fine.
Also, My 2007 pushrod had no grooves on it either...Has yours ?
joe
gotojoe is online now   Reply With Quote
Old 11-15-2012, 03:44 AM   #5
gotojoe
MV in the Registry:
[F4 1000 R]
gotojoe's Avatar
Default
Clutch Pushrod Grooves
Old 11-15-2012, 01:28 PM   #6
chay250
chay250's Avatar
Default
yes joe mine has grooves - as a matter of interest which seal are they referring that it is possible to damage?
Old 02-04-2013, 05:02 AM   #7
MaximoMarc
MV in the Registry:
[F4 1000]
MaximoMarc's Avatar
Send a message via Skype™ to MaximoMarc
Default
Just picking up on this thread - I've nosed through others which have got me a little concerned.
Was aware of issue when I took the sprocket cover off, so tried to keep it in place, but think it must have come out about a good quarter of the way when I caught it with the rag!
It went back in fine, though, and the cover is back on ok. Do I even need to worry?
MaximoMarc is offline   Reply With Quote
Old 02-04-2013, 05:45 PM   #8
theknurl
theknurl's Avatar
Wink
No worries Marc
__________________
The Forum Curmudgeon
i'm not PC either
Noel-theknurl
ph. 310-540-4823 PST, GMT -8
email, PayPal; theknurl@yahoo.com
Skype; theknurl
theknurl is online now   Reply With Quote
vB code is On
HTML code is On
Forum Jump
