#1 |
fuel line fitting dimensions;
i chopped up a perfect set because i keep seeing funny numbers from some folks the stainless fitting on the TBs is 7.8mm/0.307" the gray John Guest fitting at the used O-ring 9.44mm/0.372" the square black John Guest(?) fitting at the used O-ring 9.34mm/0.368" so the John Guests are ~3/8"-0.375"......which makes them a nominal 5/16"/8mm fitting BUT the CPC quick disconnects measure 10.68mm/0.421" or ~7/16" which makes them a nominal 3/8" fitting MV screwed up......wasn't the fitting manufacturers ![]()
__________________
The Forum Curmudgeon i'm not PC either ![]() Noel-theknurl ph. 310-540-4823 PST, GMT -8 email, PayPal; theknurl@yahoo.com Skype; theknurl |
| Sponsored Links | |
Advertisement |
#2 |
Good work Noel. Ooops on MVs part.
__________________
![]() Mitch The Hub Man Work.Email & Paypal. tweedcitytruck@onestream.com.au Work Phone (+61)0755244655 |
