# how to remove roller bearing from hub? - MVAgusta.net
log in
Forum
Go Back   MVAgusta.net > Technical and Hands On > Maintenance & Tech. Issues (All 4 Cyl. Models)
Register FAQ Members List
Thread Tools Display Modes
Old 11-13-2012, 02:37 PM   #1
chay250
chay250's Avatar
Default how to remove roller bearing from hub?
any advice on how to remove/refit the large roller bearings from the hub ? i have managed to remove the right hand side bearing (the one that falls to pieces) but am not sure howto go about removing/refitting the roller bearings.
the rubber seals look like they could easily be damaged when refitting.
cheers colin
chay250 is offline   Reply With Quote
Old 11-13-2012, 03:05 PM   #2
bogie1072
bogie1072's Avatar
Default
removed seals
remove snap rings...these are kind of a pain to remove
press out bearing
I used a socket or sized washer to press it out.
I would replace the seals, the snap clips can be reused. The larger of the two clips can be purchased from ducati (998rs hub)..the other clip you would have to source if it broke.
If you are not replacing the race and bearings there really is no need to remove and refit just to clean and grease.
bogie1072 is offline   Reply With Quote
Old 11-13-2012, 03:46 PM   #3
theknurl
theknurl's Avatar
Wink ?
Originally Posted by chay250 View Post
any advice on how to remove/refit the large roller bearings from the hub ? i have managed to remove the right hand side bearing (the one that falls to pieces) but am not sure how to go about removing/refitting the roller bearings.
cheers colin
Colin leave the needle bearing where it is, clean and regrease it
anybody notice the seal are in BACKWARDS from the Factory
__________________
Noel-theknurl
The Forum Curmudgeon
i'm not PC either
ph. 310-414-7247 PST, GMT -8
email, PayPal; theknurl@yahoo.com
Skype; theknurl
theknurl is online now   Reply With Quote
Old 11-13-2012, 04:22 PM   #4
bogie1072
bogie1072's Avatar
Default
[quote=theknurl;568196
anybody notice the seal are in BACKWARDS from the Factory[/QUOTE]
Yes but when you build a hub after a few glasses of wine who cares....forwards or backwards it don't matter can't see them with sprocket and wheel on.
Old 11-13-2012, 04:38 PM   #5
chay250
chay250's Avatar
Default
thanks for that guys - i think i will take noels advice and leave them in place for now.
Old 11-13-2012, 05:40 PM   #6
theknurl
theknurl's Avatar
Wink
i do the wine afterwards
__________________
Noel-theknurl
i'm not PC either
Skype; theknurl
vB code is On
HTML code is On
Forum Jump
Powered by vBadvanced CMPS v3.2.3
Powered by vBulletin. Copyright 2000-2010 Jelsoft Enterprises Limited.
