Adjusting the grear change - MVAgusta.net
log in
Forum
Thread Tools Display Modes
Old 11-12-2012, 05:29 PM   #1
vodkamune
Member
MV in the Registry:
[Brutale CRC]
[F3]
Question Adjusting the grear change
Hey All
I have a quick question in regards to going into neutral gear.
It seems to me that when i hold down the clutch lever the bike tends to pull forward a bit. and if i am not in a rolling position the bike has a tendancy to not change into neutral. So it seems to me that the gear changer needs to be adjusted a bit so that it does not pull.
The bike pops into neutral if it off. and if i am moving .. as soon as the bike stops it will try to skip threw the neutral gear when i sickle threw them with my foot
Thanks for your help
vodkamune is offline   Reply With Quote
Old 11-12-2012, 06:04 PM   #2
Default
It sounds more like your clutch lever may need to be adjusted not your gear lever. Have you bled the clutch slave cylinder recently?
__________________
ΜΟΛΩΝ ΛΑΒΕ
CAG is offline   Reply With Quote
Old 11-12-2012, 06:37 PM   #3
vodkamune
Member
MV in the Registry:
[Brutale CRC]
[F3]
Default
no i have not. I check to see if there is to much fluid
Old 11-12-2012, 06:55 PM   #4
Default
It is unlikely that there is too much fluid in the reservoir. Bleed the clutch slave the same way you would bleed a brake caliper and see if it helps.
__________________
ΜΟΛΩΝ ΛΑΒΕ
Old 11-12-2012, 07:31 PM   #5
Donsy
MV in the Registry:
[F4 1000 R]
Smile What CAG said
It's not that there is too much fluid in the system. The fluid can and will go bad over time, so you need to replace it. If it, the level, is very low, then you migh have a damaged seal and you will have to replace that.
Have you tried adjusting the lever out a bit to see if that makes a difference, I mean the lever that you pull with your left hand and not the gear lever.
__________________
Manuals are here - http://www.teamdouble3racing.com/manuals
Donsy is offline   Reply With Quote
Old 11-12-2012, 09:12 PM   #6
theknurl
theknurl's Avatar
Wink creepy bike?
vodkamune;
your clutch is not releasing......thats why it creeps forward
bleed it.....and you're good to go
__________________
The Forum Curmudgeon
i'm not PC either
Noel-theknurl
ph. 310-540-4823 PST, GMT -8
email, PayPal; theknurl@yahoo.com
Skype; theknurl
theknurl is online now   Reply With Quote
Old 11-14-2012, 08:31 PM   #7
vodkamune
Member
MV in the Registry:
[Brutale CRC]
[F3]
Default
how much should i bleed it for?
Old 11-14-2012, 11:33 PM   #8
Donsy
MV in the Registry:
[F4 1000 R]
Default
What do you mean by that ?
To bleed the system, we mean replace all the old fluid with new DOT4 fluid.
__________________
Old 11-15-2012, 04:40 AM   #9
silentservice703
Location: In Duxbury, MA, USA with Lee and Patty in my heart.
Send a message via AIM to silentservice703 Send a message via Yahoo to silentservice703 Send a message via Skype™ to silentservice703
Default
A quick and easy bleed would be to take the appropriate sized box-end wrench (8mm? 10mm?) and place it on the bleed nipple on the clutch slave cylinder. Put a rag over the wrench and bleed nipple. Pump the clutch lever until it its as solid feeling as it gets, then, while holding the lever to the bar, open the bleed screw with the wrench. When the bleed is complete...maybe one second...close the bleed screw and then release the clutch lever slowly. Repeat this action twice more.
This will bleed minimal fluid and release any minor amounts of trapped air at the slave.
After that you can check the clutch action.
Dons is right, however...you should renew the clutch fluid at least once a year, same as brake fluid, by doing a complete system bleed/refill.
__________________
Keep your words soft and sweet...for somday you shall eat them!
A government that robs Peter to pay Paul
can always depend upon the support of Paul.
-- George Bernard Shaw
silentservice703 is offline   Reply With Quote
vB code is On
HTML code is On
Forum Jump
