Theknurl hub bearing - MVAgusta.net
log in
Forum
Thread Tools Display Modes
Old 11-10-2012, 01:03 PM   #1
wa2fst
No MVs in the Registry
wa2fst's Avatar
Default Theknurl hub bearing
So i started replacing the bearing...very easy btw but as im looking at a sealed bearing on the wheel side and an un sealed bearing on the sprocket side..and on another post showing the sprocket side bearing being replaced with the same bearing. Im a little confused on which bearing is being replaced.
Anyone want to chime in? Noel is not near his skype at the moment.
wa2fst is offline   Reply With Quote
Old 11-10-2012, 02:48 PM   #2
theknurl
theknurl's Avatar
Wink
Al;
you're changing the sealed bearing on the wheel side, the one behind the stupid Seeger ring
when you remove the old bearing, grind the OD of the outer race about 0.008"/ 0.2mm.....then use it to press the new bearing in
if you don't grind the OD, it will stick in the hub
__________________
The Forum Curmudgeon
i'm not PC either
Noel-theknurl
ph. 310-540-4823 PST, GMT -8
email, PayPal; theknurl@yahoo.com
Skype; theknurl
theknurl is offline   Reply With Quote
Old 11-10-2012, 03:00 PM   #3
wa2fst
wa2fst's Avatar
Default
I actually started pressing it in and it friigin went in crooked almost all the way in. So i had to hammer it out and actually popped the little black seal out in between the races...guess i need to buy a new bearing and use a vise instead of C clamp. Let me know the cost
Old 11-10-2012, 05:14 PM   #4
mitchy
mitchy's Avatar
Send a message via Skype™ to mitchy
Default
Use a workshop press if you can access one.Once you start straight, away you go.To help, you can also throw the bearing in the freezer for a couple of hours and slightly warm the hub,that will help.But mainly start straight that's the trick.Good luck.
__________________
Mitch
The Hub Man
Work.Email & Paypal.
tweedcitytruck@onestream.com.au
Work Phone (+61)0755244655
mitchy is offline   Reply With Quote
Old 11-11-2012, 04:58 PM   #5
BG Wells
BG Wells's Avatar
Default
Top class advice Mitch!.............you da man!
And another great tip from Noel also!
Brian.
BG Wells is online now   Reply With Quote
Old 11-11-2012, 06:55 PM   #6
mitchy
mitchy's Avatar
Default
Thank you Brian,I appreciate the compliment,coming from a true craftsman.
__________________
Mitch
The Hub Man
vB code is On
HTML code is On
Forum Jump
