| Sponsored Links | |
Advertisement |
#2 |
![]() Join Date: Aug 2006
http://www.shoraipower.com/
I've got the lightweight Shorai Lithium-Iron in two of my bikes. They are Deltran "Battery Tender" compatible. I've had one of the two for more than a year, and so far so good.
__________________
Kevin '08 MV Agusta F4R-312-Muzzy fans, H.O. Impeller/Cover, Bodis Exhaust, Race ECU '05 Duc 749S-Track bike-Full Termi 54mm exhaust, Ohlins Steering Damper & rear spring, UES kit, 27mm Ducshop Triple Clamp, Yoyodyne Slipper Clutch, +3 rear sprocket, lightened fly wheel, DP light cambelt rollers, Evoluzione Throttle, Pazzo levers '04 Duc Monster 1000S-Arrow hi carbon slip-ons, DP Light Fly wheel & light cambelt rollers, +4 rear sprocket, CC rear sets ~Amo tutte le cose italiane~ |
#3 | |
__________________
What we've got here, is failure to communicate. Last edited by Ian SAVS : 11-10-2012 at 11:30 AM. |
#4 |
If you're going down the lithium battery route, suggest you take a look at the Antigravity Batteries. These appear to be more sturdy (also waterproof) and greater capacity and CCA's than the Shorai's. They also come in OEM 'stock' sizes, if you don't fancy padding out your battery compartment with foam.
This guy at Adventure Rider has done some pretty extensive testing (warning very long thread) and looks like the Antigravity has easily beaten the Shorai.... I bought a Shorai LFX14 last year, and it is seems fine for now, but given what I read in this review and elsewhere and the experience of a friend on this forum with a Shorai, which has lost a cell, I would stop short of recommending them. If I was buying a lithium battery now I would take a close look at the Antigravity. |
#5 | |
I got a Ballistic off ebay, it says 8 cell is ok but in reality it wasn't powerfull enough.
Sent it back and replaced it with a 12 cell. Adam Quote:
#6 | |
