| Register | FAQ | Members List | Mark Forums Read |
Thread Tools | Display Modes |
#1 |
![]() Join Date: Sep 2006
I have a question on what do You "do it yourself" maintenance or even more professional wrench heads use to service Your MV Agusta F4 or Brutale in the USA.
Me being a mechanic on gas turbines and servicing / installing them all around the globe I'm used to quite a lot of greases, fluids, sealants but they are mostly pretty specific and I don't know if this is than the best for motorcycles. further some of the stuff in the Chassis manual is hardly to find in the USA or like at Mc Master only available in never in entire life consumable amounts. I had no chances in the last decade to do much on my F4 and had still stuff as WD40, greases and things from the time where I still lived in Germany. With the last moving from PA to TN everything got lost, including tools and everything what remotely looked like flammable. Well women take care of other things than our garage items. So what do You guys use compared to the chassis manual stuff in the USA and where do You source it from? Loctite 542 Loctite 243 Loctite 242 (I have this already) Loctite 270 (have this too) Molykote (which 1000 or P37 or do they mean something completely different, is this good as a never seize on Ti stuff and exotic material mixes as well) Molykote BR2 Plus AGIP Grease 30 AGIP GR SM Silicone Grease Aluminium Tape (for the air box, which thickness, width) I really appreciate Your input and might some other do it yourself beginners will be glad for this informations as well. |
| Sponsored Links | |
Advertisement |
#2 |
Have you looked at the MV service manual,it recommends all the greases/thread locks in each section that you need to use.
__________________
![]() Mitch The Hub Man Work.Email & Paypal. tweedcitytruck@onestream.com.au Work Phone (+61)0755244655 |
#3 |
![]() No MVs in the Registry Join Date: Mar 2008
Aluminium tape at Home Depot stores( AC department ) auto parts stores sell loctite , molykote or Permatex anti-seize lubricant , As for different AGIP lubricant you can order from APRILIA AF-1 forum online . They offer several AGIP products.
#4 |
Guess where my list is from Mitchy. Yes I browsed trough the chassis service manual and collected everything in there to put it on my purchase list.
#5 | |
I'm used to learn on manufacturers home pages that certain outlets have their products but than they don't have it in their stores. Dupont dry chain lube should be available at Walmart. I drove 50 miles to the next Walmart and guess what, I ordered it over amazon. Loctite has more than 1000 products and might 200 tread lockers, my fear is that I will find Loctite but fnding Loctite 542 is likely requiring a good portion of luck. Same applies to Molykote, they have 1000+ products as well. And the service manual doesn't even specify which. I assume 1000 or P37. Both great anti seizes in my books. Further I think that the greases from AGIP are nothing designed for a space mission to Mars. So what would be an USA made equivalent ? Also I found aluminum tape on McMaster-Carr and they have different grades, glues and width of it. So what is Your recommendation ? 2 inch, 3 inch,... |
#6 |
Sorry Haupti,did not realise you have already looked in the manual.
I have and use Loctite 577 thread sealant for the metal fuel fittings in fuel tank 263 threadlocker-high strength 222 threadlocker-low strength Anti sieze paste Waterproof grease Lithium based High Temp Bearing grease All for rear hub service. Liquid Steel for glueing in rivnuts,where I cannot use the rivnut tool.Thats about it.
__________________
#8 |
__________________
The Forum Curmudgeon i'm not PC either ![]() Noel-theknurl ph. 310-540-4823 PST, GMT -8 email, PayPal; theknurl@yahoo.com Skype; theknurl |
#9 |
Thank You guys for the effort which I really appreciate. I guess You gave Your best. Yeah I will keep on browsing the www and let You all know where I sourced the stuff in the US of A. Favorable I need only one or two online retailers.
