| Register | FAQ | Members List | Mark Forums Read |
Thread Tools | Display Modes |
#1 |
my sr 750 has started idling rough when it gets hot. it only seems to do it in stop start traffic.it's going to the mechanic next week i just want to try and narrow down what could cause it
thanks rob ![]() |
| Sponsored Links | |
Advertisement |
#2 |
Rob;
check the hose clamps on the intakes.......guaranteed they're loose also the check the vacuum tubes and caps* from the throttle bodies to the side fittings *on my '05 they were cracked and leaking
__________________
The Forum Curmudgeon i'm not PC either ![]() Noel-theknurl ph. 310-540-4823 PST, GMT -8 email, PayPal; theknurl@yahoo.com Skype; theknurl |
#3 | |
thank you very much noel i'll check them i love this forum you guys are always really helpful ![]() ![]() ![]() rob ![]() |
#4 |
fixed
![]() ![]() noel your diagnosis was spot on as usual all 4 caps were cracked/split i think you should write a book.we can call it dr knurl's guide to mv mechanics lol thanks rob ![]() |
#5 |
mvrob;
the manual says replace all the in-tank lines every 3 years...... i read that as THEY know they are using low grade lines......forget ethanol, they wrote that 13 years ago....before ethanol so all fuel system rubber is suspect.....ozone eats it....it shrinks or cracks i have 2 MVs both bought used...1st thing i did? replaced fuel lines, fuel filters, vacuum lines, caps and tightened the intake clamps i started working on exotic cars in '59...if they didn't run right you looked for air leaks...... spray butane at it, if the engine changes sound... its leaking when you have some time get a tube of dielectric grease and lube EVERY electrical connector on the bike......i live 3 blocks from the Pacific Ocean......and EVERYTHING corrodes.... yet, i have NO electrical problems.......OK! my Aprilia RSVR eats stators my bikes are never on a battery tender.....and they all get 5-7years on a stock battery..... except BMWs they're battery sluts![]() coming up on 1,400,000 mi on bikes ![]() glad i could help you ![]()
__________________
#6 |
not fixed
![]() ![]() went for a ride today and the problem has returned.im going back to my mechanics tomorrow to check the vacuum hoses and clamps. thanks rob ![]() |
#7 |
Check the sensor in your left air tube.
__________________
ΜΟΛΩΝ ΛΑΒΕ Last edited by CAG : 11-13-2012 at 06:12 PM. |
#8 |
#9 |
all the clamps were loose this seems to have fixed it running rough but the idle is still rough when it gets hot.
it also slalls occasionally when idling. tried to check the sensor but the manual does not really tell you how to do it? i think it's time to take it to an official mv dealer ![]() thanks rob ![]() |
#10 |
still idling rough i'm going to the mv dealer thursday will get them to check the airtube sensor and the coils is there anything else it could be?
thanks rob ![]() |
