Race Hooks - MVAgusta.net
log in
Forum
Go Back   MVAgusta.net > Models > F3
Thread Tools Display Modes
Old 11-06-2012, 10:10 PM   #1
idahomike
MV in the Registry:
[F3]
idahomike's Avatar
Send a message via Skype™ to idahomike
Default Race Hooks
Just installed a set of race hooks to fill in the space left when I removed the pillion pegs. A nice product with high quality. Purchased from Design Corse. They were advertised for the F3, but the package was labeled F4 '10 - and I had to make some minor mods to make them fit. First the rear spacer had to be removed (17mm wrench, easy). The two long rear cap screws supplied with the hooks had to be shortened to match the front screws. It will be much easier to tie the bike down in the trailer with these hooks. Much less risk of damage to the bodywork as well.
__________________
Life Is Short, Eat Dessert First!
2013 F3 Red/Silver (Velocita)
idahomike is offline   Reply With Quote
Old 11-06-2012, 10:17 PM   #2
Ian SAVS
MV in the Registry:
[F4 1000 R]
Ian SAVS's Avatar
Send a message via Skype™ to Ian SAVS
Default
Looks good! Can you tie the bike down for transport with those alone, or do you still have to secure the handlebars?
__________________
What we've got here, is failure to communicate.
Ian SAVS is online now   Reply With Quote
Old 11-06-2012, 11:56 PM   #3
idahomike
MV in the Registry:
[F3]
idahomike's Avatar
Default
Still laughing at the Titanic comment better get a parachute, the fiscal cliff is just ahead!
Back to your question - I NEVER tie the handlebars down - too hard on fork seals. In my enclosed trailer the front wheel is in a race chock (Harbor Freight, $70) that is bolted to the trailer floor so the front suspension is free to move naturally. The race hooks will just allow me to provide some lateral and vertical stability with tie downs. Truth be known, the race chock is enough all by itself for most trips but the straps need to be there for rough roads, emergencies, etc.
__________________
Old 11-07-2012, 03:42 AM   #4
DesignCorse
King of Carbon
DesignCorse's Avatar
Send a message via Skype™ to DesignCorse
Thumbs up
Great to hear you got them and fitted them, These Racing hooks are not specific for the F3 bikes from Sato. you simply need to remove the spacer from the rear which pull off easily with a set of pliers.
The Bolts that come with the hooks fit perfectly but if you want to shorten them then either you can use the original rear-peg bolts or simply swap out the rear-set bolts with the sato ones.
__________________
Regards
Al
www.Designcorse.com
www.Designcorse.co.uk
Info@Designcorse.com
T: +44 (0) 871 789 0756
Skype Username: DesignCorse
DesignCorse is offline   Reply With Quote
Old 11-07-2012, 08:40 AM   #5
idahomike
MV in the Registry:
[F3]
idahomike's Avatar
Default
Hmmmm.....I thought that's what I just said.....except use the 17 mm open-end instead of pliers, ok?
__________________
Old 11-07-2012, 08:44 AM   #6
DesignCorse
King of Carbon
Thumbs up
Indeed you are right which ever tools you have available and i was just adding that you can swap over the Bolts from the rearsets onto the hooks and vice versa.
__________________
Regards
Al
www.Designcorse.com
Old 11-07-2012, 08:58 AM   #7
idahomike
MV in the Registry:
[F3]
idahomike's Avatar
Default
I kept the Sato bolts because they look better than the stock ones, are probably less corrosion-prone than the stock ones and - the clincher - the original peg bolts were already packed away with the pegs. Engine covers are next!!
__________________
Old 11-07-2012, 09:01 AM   #8
DesignCorse
King of Carbon
Talking
Ahh got it Mike, No worries and in regards to the engine covers we do have the GB racing in stock
__________________
Regards
Al
www.Designcorse.com
Old 11-07-2012, 09:12 AM   #9
idahomike
MV in the Registry:
[F3]
idahomike's Avatar
Default
I noticed
__________________
Old 11-07-2012, 09:21 AM   #10
DesignCorse
King of Carbon
Wink
I noticed
Indeed
__________________
Regards
Al
www.Designcorse.com
vB code is On
Forum Jump
