help req renewing steering stem bearings - MVAgusta.net
log in
Forum
Thread Tools Display Modes
Old 11-06-2012, 11:35 AM   #1
chay250
chay250's Avatar
Default help req renewing steering stem bearings
i have just removed the fork yokes from the headstock on my 312r as my steering was notchy - my suspicions were well founded as i have found that the bottom bearings are shot! looks like water ingress - do any of you guys have any tips on how to remove the bearing cups from the steering tube? also how do you remove the inner bearing from the bottom of the steering stem? done this job on a tz which aint so bad as you can get at the bearing cups in the headstock and drift them out - this is dosen't possible with the mv - having read the workshop manual i see no reference to what looks like a pig of a job.
chay250 is offline   Reply With Quote
Old 11-06-2012, 12:52 PM   #2
gotojoe
MV in the Registry:
[F4 1000 R]
gotojoe's Avatar
Default
Take it to an engineering shop and have them pull it off the stem..Suggest you fit taper rollers too..The bearing cups can be touched with weld and will crack and then drop out easily
gotojoe is online now   Reply With Quote
Old 11-06-2012, 08:14 PM   #3
theknurl
theknurl's Avatar
Wink ?
removing bearing cups......
use a bent ended punch or one with a foot on the bottom or turn it upside down and heat it with a TIG torch it will just fall down
inners from the stem.....
use a bearing separator
__________________
The Forum Curmudgeon
i'm not PC either
Noel-theknurl
ph. 310-540-4823 PST, GMT -8
email, PayPal; theknurl@yahoo.com
Skype; theknurl
theknurl is offline   Reply With Quote
Old 11-06-2012, 09:17 PM   #4
gregpilot
MV in the Registry:
[F4 1000 R]
gregpilot's Avatar
Default
use a bearing separator or turn it upside down and heat it with a TIG torch it will just fall down
I use a cutoff wheel on my moto-tool to cut a slot in the inner race, about 3/4 through it, ***very carefully*** not going through too far and damaging the stem. Then you can take a metal chisel, place it in the notch made by the cutoff wheel, and give it a good whack. The inner race will crack and you're done!
gregpilot is offline   Reply With Quote
Old 11-07-2012, 02:10 AM   #5
Donsy
MV in the Registry:
[F4 1000 R]
Default +3
All three mentioned methods will work just fine, and I agree with you, go with taper bearings as a replacement.
Here's a part number if you need it, make sure you get the replacement dust covers also.
__________________
Manuals are here - http://www.teamdouble3racing.com/manuals
Donsy is offline   Reply With Quote
Old 11-07-2012, 11:03 AM   #6
chay250
chay250's Avatar
Default
thanks for that guys - first i need the tool to undo the large ring on the headstock - merc 07 is going to make one.
donsy - have i got the bearing number correct off your picture is it >> 32907-3 ? also what make is it? not sure if the number is the same for all bearing companies or if they use their own.
cheers colin
Old 11-08-2012, 02:21 AM   #7
Donsy
MV in the Registry:
[F4 1000 R]
Default
cheers colin
Here you go Colin - 32907JR3 Narrow Section Steering Head Set Taper Roller Bearing 35x55x15mm
or
http://simplybearings.co.uk/shop/pro...ducts_id=43735
__________________
Old 11-08-2012, 11:04 AM   #8
chay250
chay250's Avatar
Default
star man mate - much obliged
colin
Old 11-09-2012, 08:56 PM   #9
theknurl
theknurl's Avatar
Wink numbers?
Colin;
almost all bearing numbers are standardized size wise
most companies use the SKF coding system for seals too
any bearing supplier can find what you want.....
the internet is NOT the place to buy bearings.....
there is an International Bearing Manufacturers Association trying to stop counterfeit bearings....i wonder who the counterfeiters are????
its the Chinese
i get mine from Charlie.....we've been friends for 30 years......
he supplies all the off road teams, he was a trials bike importer and rider
__________________
i'm not PC either
Noel-theknurl
Skype; theknurl
Old 11-09-2012, 09:10 PM   #10
Donsy
MV in the Registry:
[F4 1000 R]
Arrow Whaat - Thanks for that
Colin;
its the Chinese
I have bought from these guys before Noel and they seem to be on it, plus, how bad can a steering bearing get, not much going on in there.
__________________
vB code is On
HTML code is On
Forum Jump
