# 1090RR cooling water leaking - MVAgusta.net
log in
Forum
Go Back   MVAgusta.net > Models > Brutale B4
Register FAQ Members List
Thread Tools Display Modes
Old 11-04-2012, 08:43 AM   #1
ton2278
No MVs in the Registry
Default 1090RR cooling water leaking
HI guys
i just bought a 1090RR few weeks ago
most of time, when i turn off the engine and stop the my bike. i found out the cooling water leaking on ground sometimes. it not so much, only leaking around 30sec and it stop. also the area like a hand size on the ground.
i would like to know is it normal for this bike??
are you guys happend it before?
[IMG][/IMG]
the water is coming out from these pipes (lift one ) how to call this pipe?
[IMG][/IMG]
Is it overfilled? I can see the whole blue cooling water in the small white tank ! Is it mean too much water?
Please kindly to tell me where is lower lever?
The picture is down to the #24, which is in page 3. Please check it for me
Thank you guys :-)
ton2278 is offline   Reply With Quote
Old 11-04-2012, 08:45 AM   #2
Red Baron
Red Baron's Avatar
Default
Sounds like it's overheating.
Is the level staying or are you having to add to it?
Red Baron is offline   Reply With Quote
Old 11-04-2012, 08:49 AM   #3
V10KLZZ71S
V10KLZZ71S's Avatar
Default
Where is it dripping from, overflow? Under the shifter? If its the radiator overflow, I think they all do on occassion. Cooling system might need to be burped meaning some air is trapped in there which make it run warm. Under the engine might be water pump seal which drips out under the left side of the engine.
__________________
07 Brutale' 910R Arrow Thunder, PCIII,Ferracci chip, CRG mirrors,levers. Scotts, Motovation sliders.
O6 Yamaha FZ1
V10KLZZ71S is offline   Reply With Quote
Old 11-04-2012, 08:55 AM   #4
ton2278
Default
here is my pic
Old 11-04-2012, 08:57 AM   #5
ton2278
Default
no i dont think its overhead
Old 11-04-2012, 09:02 AM   #6
ton2278
Default
thanks for reply
i am not sure does it call overflow or not.
on the pic. you can see 2 black small pipe( it looks like a straw)
and cooling water dripping from one of it.
and it always happend !
Old 11-04-2012, 09:09 AM   #7
ton2278
Default
my water temp was not so high.
so i dont think my bike was overheating
Old 11-04-2012, 09:20 AM   #8
ton2278
Default
Old 11-04-2012, 09:24 AM   #9
ton2278
Default
the water is coming out frome this pipe
[IMG][/IMG]
Old 11-04-2012, 10:19 AM   #10
gotojoe
MV in the Registry:
[F4 1000 R]
gotojoe's Avatar
Default
There is air in the system. When you stop There is a steep temp gradient between the cylinder and the coolant in the jacket..This is no longer being circulated and so a shunt effect occurs and any air in the system expands and shoves coolant out of the overflow..
gotojoe is offline   Reply With Quote
vB code is On
Forum Jump
Powered by vBadvanced CMPS v3.2.3
Powered by vBulletin. Copyright 2000-2010 Jelsoft Enterprises Limited.
