Heatwrap..is this the solution? - MVAgusta.net
log in
Forum
Go Back   MVAgusta.net > Models > F4
Thread Tools Display Modes
Old 11-04-2012, 05:20 AM   #1
nikF4
Default Heatwrap..is this the solution?
I burnt a hole on my lower fairing a week back and was told by my mechanic that it was due to the fairing rubbing/touching the manifold... It never happened in the last three years i had the bike..I've since fixed the fairing and the mechanic put a heat wrap around the lower exhaust... Some kind of cloth cum paper material wrapped in foil... Looks neat and convincing.. My first ride wasn't very good because there was a lot of smoke and I'm sure i saw a sparks/fire when i reached the petrol station to fill her up...scared the shit out of me...got down and pushed the bike as far back i could...took it back straight to the workshop and they said it's normal...WTF?! So I made them test it and and lo and behold there was no more smoke/fire...said it was the initial burn off etc etc... This morning i went for spirited riding...When I got back, I saw some portion of the foil wrap peeled off and the paper/cloth heat shield is exposed... The wrap now has gone from convincing to shabby... But is it a solution to the heating problem in the first place? Is it recommended
by MVAgusta? Has anyone done something similar? Would love to hear your thoughts and suggestion(s) to fix the problem.. The bike is going back to the workshop but I need the problem fixed ASAP for the track day next week...
__________________
'09 F4 1078 (monoposto) + '12 Brutale 920
nikF4 is offline   Reply With Quote
Old 11-04-2012, 03:15 PM   #2
MVBERT
No MVs in the Registry
Default
There are different exhaust wraps out there, check for clearance, which model of bike do you have?
How did your fairing get damaged, did your heat shielding fall off, or did your fairing really touch the pipes, missing bracket, movement, can spacers be used, has anyone played with the manifold recently?
I have clued down parts of my heat shielding where the original adesive had failed using a glue with some heat resistance, have used it before on a 500cc 2 stroke with racing pipes that ran closer to the fairing than stock. I also replaced missing shielding and extended in other areas which I deamed were at risk. If you have the money is there a fairing available for track use?
MVBERT is offline   Reply With Quote
Old 11-04-2012, 03:50 PM   #3
mitchy
mitchy's Avatar
Send a message via Skype™ to mitchy
Default
I had the same problem with my bellypan after fitting a Bodis system.I got some Titanium heat wrap from Alex at GP Racing and it fixed the melting problem,no smoke or burning.The wrap has done a few thousand kms now and looks as good as the day I fitted it.Name:  100_1060.jpg
__________________
Mitch
The Hub Man
Work.Email & Paypal.
tweedcitytruck@onestream.com.au
Work Phone (+61)0755244655
mitchy is online now   Reply With Quote
Old 11-04-2012, 04:06 PM   #4
mikef4uk
MV in the Registry:
[F4 1000 R]
mikef4uk's Avatar
Default
I did the headers on my 1000R, mainly to stop the heat on the fans and try and reduce the temperature, some say it causes the headers to crack, but I never saw that, my lad has a mk2 golf with a 1.8T pushing over 300hp, we had to wrap the downpipe out of the turbo to stop it setting the inside of the car on fire
No cracked pipes there either in the last 5 years
__________________
(This reply has not been checked for punctuation, grammar, or spelling mistakes and is devoid of any big long cleverwords or condescending manner)
MV's all gone now, still have a soft spot for MV's, waiting for MV to tick all my boxes again.
Previously (and about 40 others)748SP, S4, S4R, 98R1, 2000 F4, F41000S, F41000R, 08R1, 09R1, S1000RR, RSV4 Factory aPRC in Garage now
mikef4uk is offline   Reply With Quote
Old 11-04-2012, 09:55 PM   #5
nikF4
Default
Thanks guys.. will snap a few pics and post here.
__________________
Old 11-05-2012, 04:41 AM   #6
Renaissance
Renaissance's Avatar
Default
Had my original cracked and degraded heat shield replaced under warranty with an improved version which has extended and thicker hard shell and fibre pad components - this combined with going to dot 5 brake fluid has resolved ongoing rear brake fading completely.
Though I rarely use the rear brake it's nice to know that it will work if I really need to.
Renaissance is offline   Reply With Quote
Old 11-05-2012, 07:13 AM   #7
obijohnkenobe
Member
MV in the Registry:
[F4 1000]
Default
My 2005 1000S has burnt a hole in the bellypan as well. Unfortunately it has now developed a missfire on one pot so have to sort that out as the priority but if anyone has a replacement silver bellypan out there....?
obijohnkenobe is offline   Reply With Quote
Old 11-05-2012, 01:11 PM   #8
guarda
MV in the Registry:
[F4 1000]
guarda's Avatar
Default
Very nice! I have some leftover wrap from my Ducati and will be doing the same in the coming weeks. Thank you.
Originally Posted by mitchy View Post
I had the same problem with my bellypan after fitting a Bodis system.I got some Titanium heat wrap from Alex at GP Racing and it fixed the melting problem,no smoke or burning.The wrap has done a few thousand kms now and looks as good as the day I fitted it.Attachment 65919
__________________
Art
guarda is offline   Reply With Quote
Old 11-07-2012, 08:08 AM   #9
nikF4
Default
Decided to remove the wrap and fit self-made brackets to steady the fairings and prevent it from touching the pipes..also bought the wrap from Design Corse.. Will update on performance especially after the track days next week..
__________________
Old 11-07-2012, 10:38 PM   #10
mitchy
mitchy's Avatar
Default
I wrapped the midpipe for 2 reasons,one to deflect heat from the rear brake master cylinder and to insulate the bellypan.I also put some more self adhesive tape on the bellypan itself.So far so good,no more blistering.Boy that Bodis runs hot!
__________________
Mitch
The Hub Man
vB code is On
Forum Jump
