#1 |
First I had a Shorai in my bike, it sat for 3 months, dead. No way to charge it so I bought a cheapo Autozone replacement, actually I bought 2 and put one in my Yamaha FZ1 at the same time.Rode the MV quite a few times, no problem. FZ1 just sat other than an occassional start up. Anyway, my brutale sat for about 1 month, dead battery. Jumped it off, ran it for about 2 hrs, started up good multible times. Next morning......click click! WTF? Any ideas on what could be causing a drain?
__________________
07 Brutale' 910R Arrow Thunder, PCIII,Ferracci chip, CRG mirrors,levers. Scotts, Motovation sliders. O6 Yamaha FZ1 |
| Sponsored Links | |
Advertisement |
#2 |
Everything visible is working normal, no light/blinker etc issues which might indicate a spu problem.
***Members here who I was friends with on facebook, I did not unfriend yall, I deleted my FB for good.***********
__________________
#3 |
![]() Join Date: Jun 2007
Is your Alternator going ?
__________________
In the Garage today... '10 Nightster '05 Brutale S |
#4 |
![]() Join Date: Aug 2009
Tim might be right, your alternator might not be charging, have a look through the manual and test the charging voltage at the battery.(Easy to do and hopefully all is good here)
The MV's do have a drain problem and will drain a weak or poor quality battery very quickly though. Make sure you take the bike for at least a good 20min ride and see what it does. |
#5 |
Thanks! I will check that when I get in from the rig.
__________________
#6 |
Member
Good idea to keep Battery Tender on when sitting.
__________________
Stop Global Whining |
#7 |
Wills;
you keep a tender on your car?? 1,375,000 mi on bikes and never a battery tender my '66 Big Block Chevy at 327,000 mi has the original alternator.... a 37 Amp Delco........and a 200 Watt PER channel amp MVs have a 51 Amp Denso alternator.......controlled by the ECU i wonder where the problem is? ![]() ![]() ![]() ![]() ![]() i put 11,000 mi on my '08 Brutale...... it used a low beam bulb, thats, IT NO PROBLEMS, PERIOD OK and tires twice......brake pads should be due soon oh, thats right a Mitch hub and a MicroTec ECU are installed too
__________________
The Forum Curmudgeon i'm not PC either ![]() Noel-theknurl ph. 310-540-4823 PST, GMT -8 email, PayPal; theknurl@yahoo.com Skype; theknurl Last edited by theknurl : 11-05-2012 at 01:07 AM. |
#8 |
With all due respect, Noel....those of us who live in colder climes than you fortunates in Cali NEED tenders.
Batteries lose voltage by design over time...we've been through this. Yes, I keep my cars on tenders if I am not going to drive them in a month...the lawn tractor gets one too. I can have batteries last well past their 5 year design life by doing so. Tenders, good ones, are a good idea...and they keep weak batteries ready to go. If you get a really good smart charger, it will also de-sulfate and restore batteries.
__________________
Keep your words soft and sweet...for somday you shall eat them! A government that robs Peter to pay Paul can always depend upon the support of Paul. -- George Bernard Shaw |
#9 |
Member
No MVs in the Registry Join Date: Nov 2009
I use Battery Tender+ and BT Juniors on all my vehicles. Plug in a BT+ each night on my '95 M3 and unplug it in the morning. The OE Douglas battery lasted 13 years under this regimen. Plug in a BT junior each morning on whichever one of the 14 bikes I'm heading out on that day. Generally get 7 to 10 years service out of the bike batteries. It does get brisk here in the mountains though. -27 degrees F is the nippiest I've seen so far. It also rarely exceeds 85 F on the hottest summer days.
#10 | |
Member
__________________
