MV F4 1000S: Radar & Laser shifter installed - MVAgusta.net
log in
Forum
Go Back   MVAgusta.net > Models > F4
Thread Tools Display Modes
Old 09-20-2012, 01:04 PM   #1
Timster
MV in the Registry:
[F4 1000]
Timster's Avatar
Exclamation Radar & Laser shifter installed ('05 F4)
I'm back
After my last hefty speeding ticket i decided it was time to install an Escort 9500ci system on the MV. It has radar front/back, GPS and front and rear laser shifters.
I'll probably pick it up this evening. Installation was done at Aston Martin Atlanta. Everything was very thought out and due to the limited space we had to be creative with the placement of things but it all fit and is very concealed.
Rear radar & laser shifter
Front Laser shifters (circled)
GPS antenna & main box
Front Radar detector hidden in faring
Work in Progress
__________________
__
MV F4 1000 S Red/Silver
HUSABERG FS 570
Timster is offline   Reply With Quote
Old 09-20-2012, 02:23 PM   #2
Djester
Ball & Chain magnet
MV in the Registry:
[F4 1000]
Djester's Avatar
Send a message via Yahoo to Djester
Thumbs up
Everything looks great !!!
Just as a precaution, the ECU area gets very hot.
I'm not sure how heat sensitive the device is that's placed on the ECU, but it might be a good idea to have a raised mount added if there's room.
Looks to be a hell of a kit (to install as well).
__________________
If at first you don't succeed, use a hammer instead
Djester is offline   Reply With Quote
Old 09-20-2012, 02:26 PM   #3
Djester
Ball & Chain magnet
MV in the Registry:
[F4 1000]
Djester's Avatar
Default
Please post "system on" pics of the display unit. I'm curious to how bright it is and if there'd be a need to cover it incase the locals come investigating.
__________________
Old 09-20-2012, 02:32 PM   #4
Timster
MV in the Registry:
[F4 1000]
Timster's Avatar
Default
It's legal in GA. No worries.
__________________
__
HUSABERG FS 570
Old 09-20-2012, 02:37 PM   #5
Timster
MV in the Registry:
[F4 1000]
Timster's Avatar
Default
If need be i can install a heat shield between the ECU and box but I'm pretty sure its fine. Yes its difficult to install. They did a hell of a job. All cables are wrapped in heat shrink tubes. There will be no visible wires. It took them 2-3 days. I haven't seen the bill. Its not cheap but cheaper than some more tickets.
__________________
__
HUSABERG FS 570
Old 09-20-2012, 04:23 PM   #6
brusta
Banned
No MVs in the Registry
Default
looks amazing!
brusta is offline   Reply With Quote
Old 09-20-2012, 06:41 PM   #7
Timster
MV in the Registry:
[F4 1000]
Timster's Avatar
Smile
Here you go. I just picked her up. Works great! I'm using a bluetooth system for sound. The led lamp above the display flashed red for radar and I think blue for Laser.
__________________
__
HUSABERG FS 570
Old 09-20-2012, 06:51 PM   #8
iamlance
iamlance's Avatar
Default
When did you move?? Aston Martin?? Let's see pics. Oh, Hi!!
iamlance is offline   Reply With Quote
Old 09-20-2012, 07:17 PM   #9
Timster
MV in the Registry:
[F4 1000]
Timster's Avatar
Default
Hey man, I moved 6 months ago. Kinda in a rush.
Here's the DB9 with DBS wheels:
__________________
__
HUSABERG FS 570
Old 09-20-2012, 09:09 PM   #10
MVista
Default
A mod that EVERY bike should have - amazing install!
Too bad that will land you in jail where I come from
__________________
MVA - Maserati Vespa Agusta
MVista is offline   Reply With Quote
vB code is On
Forum Jump
