#1 |
I am confronted with following problem: gear indicator sometimes indicates a gear lower than the gear where i am in or start to change perpetually (for instance between 5 and 6 when i am in 6th gear).
Did anyone encounter the same problem? Could it be fixed easily? Peter |
| Sponsored Links | |
Advertisement |
#2 | |
Dealer has obtained a new switch which is to be fitted in the next week or so. Will let you know if it solves the problem |
#3 | |
__________________
Life Is Short, Eat Dessert First! ![]() 2013 F3 Red/Silver (Velocita) |
#4 |
No MVs in the Registry Join Date: Jun 2012
Mine has done the same type of thing several times. I am wondering if the sensor is the one located just below the front sprocket. If so I have noticed a small amount of chain lube or grease that has fallen down onto the wiring harness there and wonder if that could be the culprit...
#5 | |
__________________
Life Is Short, Eat Dessert First! ![]() 2013 F3 Red/Silver (Velocita) Last edited by idahomike : 09-19-2012 at 08:52 AM. |
#6 |
Member
+1
#8 |
idahomike...gotcha. Yeah when mines off it's always showing a lower gear, never higher. Prob something they should eventually issue a recall for...along with the side stand sensor. Mine has shown a warning light on that once before and I have seen a few others have this problem before. The gear indicator isn't really a big issue for me tho as I'm not used to having one anyways.
#9 |
No MVs in the Registry Join Date: Aug 2012
I test rode an F3 around 6 weeks ago and noticed the gear indicator kept changing as I was riding along. I hope the new batch in the uk will have this sorted. If your going to have a feature like this on a bike then it should work. If it only works intermittently then dont bother putting it on the bike.
#10 |
Same here, in fact I’ve encountered most, if not all the issues listed in the “Known Issues” thread, of which I have updated.
__________________
the Dreamer (a.k.a. Dreamin' Stephen) '13 675 MV F3 Red Molly '98 900 SS FE silFEr Living life on the edge. Less crowded, better view. |
