Crashed F4, advice please! - MVAgusta.net
log in
Forum
Go Back   MVAgusta.net > Models > F4
Thread Tools Display Modes
Old 09-16-2012, 11:23 AM   #1
skycat
MV in the Registry:
[F4S 750]
[F4S 750]
Default Crashed F4, advice please!
I crashed my F4 yesterday, unbelievable, I love that bike. Had it years and never crashed. Cried a lot (I'm female) then took myself outside and had a word, gave myself a beating etc etc
Anyway... does anyone know where the tilt switch/ fuel pump cut-out thingy is situated so I can reset it and try to get him started again?
And does anyone sell cheap F4 parts??
Thanks guys,
Gill-stupid-muppet-face-bloody-idiot
skycat is offline   Reply With Quote
Old 09-16-2012, 12:07 PM   #2
toddburk
MV in the Registry:
[F4 MY2010+]
toddburk's Avatar
Default
JDS or Ade or any sponsor for parts. All good folks to work with. Donsy can give excellent advice on mechanical issues. Good luck.
__________________
2007 F41000R
2010 Ducati SF
2008 MV Brutale 910 S
2007 Ducati Monster S4Rs
2006 Triumph Speed Triple
toddburk is offline   Reply With Quote
Old 09-16-2012, 12:10 PM   #3
R1andrew
MV in the Registry:
[F4 1000 R]
R1andrew's Avatar
Default
Where are you located? Lots of stock used parts on Ebay and CAG also can help you out with parts.
R1andrew is online now   Reply With Quote
Old 09-16-2012, 12:15 PM   #4
skycat
MV in the Registry:
[F4S 750]
[F4S 750]
Default
Thanks guys, I'm in Manchester UK. JDS is getting back to me tomorrow with parts info so hopefully it'll be sorted. I will ask him the switch question too. Looked on ebay but only thou parts listed.
Old 09-16-2012, 12:25 PM   #5
The_castle
The_castle's Avatar
Send a message via Skype™ to The_castle
Default
Are you OK?
Sorry to read about the crash.
__________________
It ain't what you ride, it's the way you ride it.
The_castle is online now   Reply With Quote
Old 09-16-2012, 12:27 PM   #6
skycat
MV in the Registry:
[F4S 750]
[F4S 750]
Default
Thanks 'castle'. I'm gutted, but physically okay thanks courtesy of my new Dainese leathers, just bruises and aching. I got dumped today too so it's been a blinding weekend!!!!
Old 09-16-2012, 12:35 PM   #7
gotojoe
MV in the Registry:
[F4 1000 R]
gotojoe's Avatar
Default
I believe they were fitted to bikes from 2006 onwards. The function is to cut power to the fuel pump so I am guessing the ecu picks up the sense signal when the bike tips and shuts off the fuel pump.?
I can't see a procedure to reset as such maybe one of the other guys could advise on that.
I'd check the obvious too like the kill switch isn't still pressed in ..we've all done it ; ) Then I'd check the fuses too.
Bar in mind many parts on 750s are in common with thous...
As to Location if you have one on your bike it sits just below the fuel injection rail ,to the left and behind the engine, looks like a black tube. It is connected with three wires from the bottom of the switch..
joe
gotojoe is offline   Reply With Quote
Old 09-16-2012, 12:41 PM   #8
skycat
MV in the Registry:
[F4S 750]
[F4S 750]
Default
Thanks Joe.
I've checked the fuel pump switch [i meant fuse], and the kill switch, all okay. And it's an early MV so therefore hasn't got a tilt switch, thanks for this, explains why I couldn't find it :-s
Am hoping I won't have to get it recovered to the dealer, so I'll keep looking...
Old 09-16-2012, 12:41 PM   #9
G21090
G21090's Avatar
Default
Sorry to hear about your crash. I'm glad you're physically ok. Hopefully you'll get things sorted quickly.
I'd say with your luck the past few days a pint or 10 is in order!
Cheers,
Glenn
__________________
x
G21090 is offline   Reply With Quote
Old 09-16-2012, 12:44 PM   #10
The_castle
The_castle's Avatar
Default
Good work Joe.
There is a reference to the tilt switch in the F4 manual. However, in the diagnostic section of the manual all it says is "Electric starter does not work: Tilt Sensor Broken: Replace".
No mention of a reset procedure.
__________________
vB code is On
Forum Jump
