I'm at a loss, new voltage regulator lasted 10 min. - MVAgusta.net
log in
Forum
Thread Tools Display Modes
Old 09-05-2012, 08:29 PM   #1
jchaplin4
jchaplin4's Avatar
Default I'm at a loss, new voltage regulator lasted 10 min.
I'm seriously almost done. I started it up after the alternator was fixed and put back in. Ran beautifully. So came in, thought I was done. Went out a couple hours later. Bike would fire, then die immediately. Checked fuel lines, blah blah. Then thought, well this sounds familiar. Let's unplug the alternator. Bike started and ran but poorly. Plugged alternator in while it was running, it promptly died. So seriously what the fing f f f f f f f f f is going on? I'm done with this problem and want to ride.
jchaplin4 is offline   Reply With Quote
Old 09-05-2012, 09:06 PM   #2
R1andrew
MV in the Registry:
[F4 1000 R]
R1andrew's Avatar
Default
Very sorry to hear. Wish I could help. Hope Carl, Noel, or Dons will be able to help you.
R1andrew is offline   Reply With Quote
Old 09-05-2012, 09:22 PM   #3
mitchy
mitchy's Avatar
Send a message via Skype™ to mitchy
Default
Have you contacted the company that repaired it and told them what happened?
__________________
Mitch
The Hub Man
Work.Email & Paypal.
tweedcitytruck@onestream.com.au
Work Phone (+61)0755244655
mitchy is online now   Reply With Quote
Old 09-05-2012, 09:42 PM   #4
Default
Something's killing your voltage regulator. Could it be the alternator?
__________________
ΜΟΛΩΝ ΛΑΒΕ
CAG is offline   Reply With Quote
Old 09-06-2012, 12:13 AM   #5
mikef4uk
MV in the Registry:
[F4 1000 R]
mikef4uk's Avatar
Default
Or something to do with unplugging/plugging it back in it whilst the bike is running?
__________________
(This reply has not been checked for punctuation, grammar, or spelling mistakes and is devoid of any big long cleverwords or condescending manner)
MV's all gone now, still have a soft spot for MV's, waiting for MV to tick all my boxes again.
Previously (and about 40 others)748SP, S4, S4R, 98R1, 2000 F4, F41000S, F41000R, 08R1, 09R1, S1000RR, RSV4 Factory aPRC in Garage now
mikef4uk is offline   Reply With Quote
Old 09-06-2012, 12:55 AM   #6
jcctx
MV in the Registry:
[F4 1000]
Default
Is the problem that its a pain to start? I was thinking of going down the same road as you with an alternator. But, if didn't help and your having the same issue I was also thinking of trying the starter relay. Mine has over heated and melted slightly. I removed it cleaned the contacts and it seems to start better. But I think that might be whats giving me my problems. Have you ever blown and melted the 40amp fuse there?
jcctx is offline   Reply With Quote
Old 09-06-2012, 03:25 AM   #7
gotojoe
MV in the Registry:
[F4 1000 R]
gotojoe's Avatar
Default
I agree Mike...Unplugging/plugging the alternator could cook the diodes in the regulator ?. This has to be a no no.
joe
gotojoe is offline   Reply With Quote
Old 09-06-2012, 05:59 AM   #8
jchaplin4
jchaplin4's Avatar
Default
It starts fine, strong, no issues. I have never unplugged it while running until AFTER it wouldn't start, so the damage was already done by whatever did it. It will not stay running now at all with it plugged in and runs bad w it unplugged.
Old 09-06-2012, 06:53 AM   #9
jchaplin4
jchaplin4's Avatar
Default
I hadn't told them yet because it was 8p before I went to leave for a ride and realized I still had a problem. At work today till 3. Next is a new alternator. If that comes off again, a new one is going on as impossible as a job it is to do.
Old 09-06-2012, 07:07 AM   #10
minime
minime's Avatar
Default
I assume you check the alternator with a multimeter before ripping her out?
__________________
Slow is smooth and smooth is fast!!
minime is offline   Reply With Quote
vB code is On
HTML code is On
Forum Jump
