| Register | FAQ | Members List | Mark Forums Read |
Thread Tools | Display Modes |
#1 |
Member
No MVs in the Registry Join Date: Jul 2012
Hello fellow riders. Decided to go w/ D3 tail tidy. IMO the cleanest if not one of the cleaner setups currently available. Material & build quality is excellent. Went w/ Rizoma Zero-11 indicators. Personally not a fan of the big stock signals. Could've gotten sleeker indicators like the Rizoma actions or track-77 but keeping the budget low as possible & not having to sacrifice quality, Zero-11s was a good option for me.
W/no service manual avail yet frm my dealer, I was on pins & needles when removing entire rear plastics careful not to break anything. Lil courage & guess work is all it took to get the job done. The rear tail clean up outcome & knowledge I gained about the bike was all worth the effort. I see a lot of nice F3 projects in this forum. Keep up the good work. Cheers! Special acknowledgment goes out to forum member, Dan aka Perfect for shooting me some tips. Shout out to Darren & their team over at http://www.d3-components.co.uk/ great product & customer service. |
| Sponsored Links | |
Advertisement |
#3 |
Member
Thanks! U can remove the old one & install the new one w/out having to remove any of the rear plastics. But, if you're after the clean look & wanna hide the wires then plastics would have to be removed. I was able to tuck all wires in zip-tied neatly as possible under the tail behind the black plastic piece. Plenty of room inside to stuff all the necessary wires in.
#7 |
Member
Thanks! No problem. Anything to help my fellow riders still on the fence of which tail tidy option to go with. D3 works best for me & i hope it'll work best for you. I've read & seen pics of certain troubles regarding the MV corse tidy some are having.
#8 |
No MVs in the Registry Join Date: Jun 2012
I just ordered the D3 tail tidy in MINI form.
"The MINI one uses our small LED plate light and has 10mm single hole for aftermarket indicators." Do I assume that universal aftermarket indicators fit this diameter, as I can not see any websites saying that their indicators have specific screw in specifications. Thanks |
#9 | |
Member
#10 |
Yes it makes the rear end look so much better! I am undecided between the Zero 11 (yours) and the Action Indicators though. Like you said the 'Actions' are very sleek so I may go with them.
Also, is the only other thing I need the turn signal cable kit for MV's? Other brands suggest that you need a special resistor to manage the different voltages being output from the bikes electronic system. Is that basically what the turn signal cable kit does/is? Cheers |
