#1 |
![]() Join Date: Jan 2009
Does the engine have to be removed in order to remove the clutch and change the shift drum
| Sponsored Links | |
Advertisement |
#2 |
no;
you must remove the complete clutch.....careful, the wiring harness will try to tear the gasket then sprocket cover, sprocket, chain and water pump do not remove it with the transmission in neutral a 2nd pair of hands will make it faster, depending how familiar you are with transmissions
__________________
The Forum Curmudgeon i'm not PC either ![]() Noel-theknurl ph. 310-540-4823 PST, GMT -8 email, PayPal; theknurl@yahoo.com Skype; theknurl |
#3 | |
![]() Join Date: Aug 2009
#4 |
dont forget, that the chain will prevent the
transmission to slide out. my solution is to support the bike, remove the swing arm rod, push and pull the swing arm a bit to the back, then the transmission goes out smooth. alternative method --- cut the chain ![]() happy to know, if anyone knows a more elegant way to do it. |
#5 |
I break the chain.
#6 |
![]() No MVs in the Registry Join Date: Oct 2007
If you're changing the drum to get GP shift it's alot easier and less hassle to modify the shift arm and rotate it. What I did on my Tambo.
__________________
I got mine. Boy do I ever got mine. |
#7 |
He has gp shift drum now, Lee, he wants to go the other way.
__________________
ΜΟΛΩΝ ΛΑΒΕ |
#8 |
#10 |
Thank you very much George, I received the shift drum today. Much appreciated man !
