MV Augusta Corse Tail Tidy Failure - MVAgusta.net
log in
Forum
Go Back   MVAgusta.net > Models > F3
Thread Tools Display Modes
Old 08-18-2012, 07:20 AM   #1
Bruce Taylor
MV in the Registry:
[F3]
Bruce Taylor's Avatar
Send a message via Skype™ to Bruce Taylor
Default MV Augusta Corse Tail Tidy Failure
Complete failure, appears to be metal fatigue, new tail tidy and indicators now required and probably a new tyre.
Damage to the tail fairing which is disappointing.
At first I thought it was a tyre failure, fortunately two colleagues were following and they were able to go back and collect the remains.
Quiet ride home though, looking out for the police!!!
Will take up the problem with MV
Bruce Taylor is offline   Reply With Quote
Old 08-18-2012, 07:46 AM   #2
SteveB_Ire
No MVs in the Registry
SteveB_Ire's Avatar
Default
Nasty that is a real shame as long as you are ok......but far from perfect.
__________________
F3 Serie Oro 14/200
SteveB_Ire is online now   Reply With Quote
Old 08-18-2012, 08:18 AM   #3
Trepis_Toni
Trepis_Toni's Avatar
Default
Holy shit...
Is it an alloy plate that broke or is it made od steel?
Typical design mistake - the bending of a thin sheet.
Yesterday I have dismount the original tail-tidy, I was shocked how heavy it is.
Think I will make my own design ;-)
Trepis_Toni is offline   Reply With Quote
Old 08-18-2012, 08:44 AM   #4
ondgas
ondgas's Avatar
Send a message via AIM to ondgas
Default
That gets a big booooo. Sorry bro. Glad you are o.k. rest can be fixed. Might wanna try the ondgas edition tail tidy.
ondgas is offline   Reply With Quote
Old 08-18-2012, 08:46 AM   #5
MVNoob
Default
Huge bummer. Best of luck in dealing with MV and getting it straightened out...
MVNoob is offline   Reply With Quote
Old 08-18-2012, 08:49 AM   #6
MVF3_40
Default
Settle for nothing less than total replacement of affected parts.
Unacceptable for a complete failure where no impact has occurred.
Unless of course that gouge is where your tyre picked something off the road surface and shot it into the tail tidy.
Sent from my GT-I9100 using Motorcycle.com App
MVF3_40 is online now   Reply With Quote
Old 08-18-2012, 08:49 AM   #7
Bruce Taylor
MV in the Registry:
[F3]
Default
Originally Posted by Trepis_Toni View Post
Holy shit...
It is the steel bracket that has broken, flat surface, no bends, definitely will require a new tyre, cut is down to the steel brace.
Have sent e-mail along with photos to EvolutionBike who I purchased the tail tidy from. It will be interesting to receive the response to the fault.
Old 08-18-2012, 08:52 AM   #8
Bruce Taylor
MV in the Registry:
[F3]
Default
No convinced it was failure if the tail tidy that damaged the tyre
Old 08-18-2012, 08:54 AM   #9
haupti
haupti's Avatar
Default
It looks like the hinge bolts between the plate and the holder came / were lose or they can't securely hold the plate holder in place. The scenario was probably that the plate holder moved down under the vibrations until it touched the wheel. That the sheet metal broke is likely the result of it. And I think the later is the good thing of the entire incident. Imagine it wouldn't have broken.
Now I think a little hole between the two parts, near to the hinges, filled with a little pin or bolt would avoid such disaster.
Nevertheless You have to inform MV Agusta (Dealer / Importer / Manufacturer) about it and they should revise their design to make it bullet proof. Compensation for the damage should be a no brainer.
haupti is offline   Reply With Quote
Old 08-18-2012, 09:06 AM   #10
Bruce Taylor
MV in the Registry:
[F3]
Default
Nylock hinge nuts and the tail tidy bolts to bike are 100% secure, no reason to cause the failure
vB code is On
Forum Jump
