Stands for the F3 - MVAgusta.net
log in
Forum
Thread Tools Display Modes
Old 07-25-2012, 09:59 AM   #1
idahomike
MV in the Registry:
[F3]
idahomike's Avatar
Send a message via Skype™ to idahomike
Default Stands for the F3
I'm looking to see if I can modify my Ninja Pit Bull stands for the F3. The rear stand doesn't look like it will be too difficult, but since my Red/Silver F3 is not likely to be here for a while (West Coast, USA), I'm looking for some info for the front stand. When I saw the F3 at the Seattle Show, it looked like the steering stem was hollow on the bottom and that maybe an adapter pin could be made for the Ninja front stand that would fit into the F3 steering stem. Could any of you that has the bike now tell me if that is the case and if so (really asking a lot!) what the diameter and depth of the stem opening is. Thanks in advance.
__________________
Life Is Short, Eat Dessert First!
2013 F3 Red/Silver (Velocita)
idahomike is online now   Reply With Quote
Old 07-25-2012, 08:00 PM   #2
shashankmittal
No MVs in the Registry
shashankmittal's Avatar
Default
I have similar dilemma. Although I don't have a front stand, I may have to buy one for the F3 since my Bursig paddock stand that I have been using all these years, isn't compatible with the F3. Bursig informed me that they are looking for a F3 in Germany to design the adapter plate for it.
All F3 owners in Germany, please contact Bursig about the paddock stand, you'll be able to get one free for yourself if you let them use your bike for prototyping!
__________________
2013 F3 red/silver (sold)
2010 BMW S1000RR (track only)
2004 Royal Enfield 500 Electra
1997 Yamaha RX135
1990 Yamaha RD350
shashankmittal is offline   Reply With Quote
Old 07-26-2012, 09:40 AM   #3
PTsalas
PTsalas's Avatar
Default
QUICK HIJACK,
Regarding the rear padock stand, what size insert do I need to buy to get the padock stand to work with the F3? Is it the same as the F4?
Also is MV Agusta the same as Ducati?
PTsalas is offline   Reply With Quote
Old 07-26-2012, 09:57 AM   #4
Stephen W.
MV in the Registry:
[F3]
Stephen W.'s Avatar
Default
Originally Posted by PTsalas View Post
QUICK HIJACK,
Regarding the rear padock stand, what size insert do I need to buy to the padock stand work with the F3? Is it the same as the F4?
Sprocket side of an F3 is the same as on an F4, 43mm I.D.
Sprocket side of an M796 is only 26mm I.D.
I don't know the size used on the Ducati Super bikes but I believe they are not the same as the MV’s. My dealer told me they have to specify MV pins when ordering the Pit Bull stands they sell.
__________________
the Dreamer
(a.k.a. Dreamin' Stephen)
'13 675 MV F3 Red Molly
'98 900 SS FE silFEr
Living life on the edge. Less crowded, better view.
Stephen W. is offline   Reply With Quote
Old 07-26-2012, 01:44 PM   #5
esq'z me
Default
I think the Ducati 1098 is same as MV....go to the PitBull web site an do a little research.
__________________
'08 910R, '04 F4 SPR #275 Track Bike, YSR50 restoration project, '71 CB100, '78 ATC70
esq'z me is offline   Reply With Quote
Old 07-27-2012, 06:17 AM   #6
SteveB_Ire
SteveB_Ire's Avatar
Default
I have on order and is in the post today HARRIS RACE FRONT UNDER-YOKE TYPE PADDOCK STAND...have used harris stand in the past and they are always top notch. As and when it arrives I will post some snaps.
__________________
F3 Serie Oro 14/200
SteveB_Ire is offline   Reply With Quote
Old 07-30-2012, 12:11 PM   #7
MiloMV
Member
MiloMV's Avatar
Default
The MV Agusta Factory rear stand is pretty nice looking, and is only about 100 bucks more than a pitbull
http://www.mvagusta.it/common/shop/s...rno-f4/brutale
Plus it says MV Agusta on it..
MiloMV is offline   Reply With Quote
Old 07-30-2012, 01:35 PM   #8
shashankmittal
Default
Do you know if it is reversible?
__________________
1997 Yamaha RX135
1990 Yamaha RD350
Old 07-30-2012, 07:38 PM   #9
Stephen W.
MV in the Registry:
[F3]
Stephen W.'s Avatar
Default
Just bought an MV pin for our Pit Bull stand. There are actually two pins marked 1098. F0027-002 only fits 1098 / 1198. I’m not sure why it’s marked so because it’s smaller and didn’t fit the 1098 in the showroom. The other, F0027-001 is double marked with 1098 & MV. It fit the 1098 but more importantly my F3, and really that’s all that mattered.
__________________
the Dreamer
Old 07-30-2012, 07:54 PM   #10
shashankmittal
Default
Does the 43mm pin fit both the sprocket side and wheel side, if I need to use a reversible stand?
__________________
1997 Yamaha RX135
1990 Yamaha RD350
vB code is On
HTML code is On
Forum Jump
