Need help with Indicators - MVAgusta.net
log in
Forum
Thread Tools Display Modes
Old 04-14-2012, 07:42 PM   #1
F4RUSTY
Member
MV in the Registry:
[F4 1000]
F4RUSTY's Avatar
Default Need help with Indicators
Hi guys, i have a problem with the indicators on my 05 F4 1000S. When i turn them on they flash up to 15 times then they just stay lit up, if i turn them off & back on straight away they still stay lit up but if i leave them off for a bit they work for 15 or so more flashes. The front are standard and the rear are LED. When i got the bike i was told it had a LED controller, but i am unsure what or where this is. If anyone has any ideas i would appreciate the advise. Thank you Russell.
F4RUSTY is offline   Reply With Quote
Old 04-16-2012, 08:43 AM   #2
token
MV in the Registry:
[F4S 750]
Default
im assuming that all the bulbs stay lit and not just one side? but under the left hand fairing there is a group of 3 relays.....the middle one is the flasher relay. i would start there.
i had this problem on my f4 750. replaced that unit and everything wne tback to normal.
token is offline   Reply With Quote
vB code is On
HTML code is On
Forum Jump
