# Cam chain tensioner bolt. - MVAgusta.net
log in
Forum
Go Back   MVAgusta.net > Technical and Hands On > Maintenance & Tech. Issues (All 4 Cyl. Models)
Register FAQ Members List
Thread Tools Display Modes
Old 03-11-2012, 07:01 AM   #1
merc07
MV in the Registry:
[F4 1000]
Default Cam chain tensioner bolt.
The new black type cam chain tensioner comes with two bolts for the pin/spring.
1 x Gold, 1x Black
The gold one has a thicker wall.
Which one are you supposed to use ?
I'm guessing you just swap like for like with the old..
Adam
merc07 is offline   Reply With Quote
Old 03-11-2012, 09:05 AM   #2
gotojoe
MV in the Registry:
[F4 1000 R]
gotojoe's Avatar
Default
That's correct Adam. I have noticed this with the tensioners. Have a word with Mark at Timemachine UK on the UK Forum mvagustauk forum
Let us know what is wot
joe
gotojoe is offline   Reply With Quote
Old 11-11-2012, 03:28 PM   #3
gregpilot
MV in the Registry:
[F4 1000 R]
gregpilot's Avatar
Default
joe
I am looking for a tensioner, there are new ones (P/N 8000A5206) on ebay for 168.00 US, it appears to be the factory upgrade kit with the different bolts.
Did you determine which bolt should be used with what model 1000?
gregpilot is offline   Reply With Quote
vB code is On
HTML code is On
Forum Jump
Powered by vBadvanced CMPS v3.2.3
Powered by vBulletin. Copyright 2000-2010 Jelsoft Enterprises Limited.
