Brutale Brake Issue, etc. - MVAgusta.net
log in
Forum
Go Back   MVAgusta.net > Models > Brutale
Thread Tools Display Modes
Old 02-09-2006, 03:27 PM   #1
MVorBMW
No MVs in the Registry
MVorBMW's Avatar
Question Brutale Brake Issue, etc.
Appreciate any thoughts on the fix for an odd brake issue. Every now and then I lose the rear brake. The pedal is dead, but comes back relatively fast. Feels like a loss of pressure. A little disconcerting and happens every once and awhile. Can't quite tell if there is a pattern to the failure. If there was a diagnosis floating around, it might make my service a little easier/shorter - rather than let my dealer try to figure it out. Also, while I'm seeking assistance, my trip odometer doesn't seem to work. Is there anything unusual about the use of the button. Maybe I'm not holding it down enough, etc Thanks for any thoughts
MVorBMW is offline   Reply With Quote
Old 02-09-2006, 05:04 PM   #2
Gladio
Gladio's Avatar
Default
The rear brake has always been an issue. How many miles do you have on yours.
You can read a bit about it in the FAQ
http://mvfaq.blogspot.com/2005/09/re...elocation.html
__________________
Jack
Gladio is offline   Reply With Quote
Old 02-09-2006, 05:31 PM   #3
MVorBMW
MVorBMW's Avatar
Default
Thanks Gladio...I will be honest and note that the "easy" bleeding looks a little complicated to me. I will take it to the dealer. I have about 3,000 miles on the bike. I bought an '04 with 2,500 miles about 2 months ago when my local dealer priced it to move. It's now my favorite bike and I'm upgrading to the 910r. But I should get this fixed...when I let people ride it I always wonder if I should tell them they might lose the brakes!
Old 02-09-2006, 05:52 PM   #4
Gladio
Gladio's Avatar
Default
The rear brake on my F4 has never worked, and many are in the same boat. But I rarely use the rear break on any of my bikes.
__________________
Jack
Old 02-09-2006, 08:34 PM   #5
MVorBMW
MVorBMW's Avatar
Default
Interesting...I didn't realize the problem was that bad. Seems like something that could and should be fixed. With our without a rear brake it's still the best bike I've ridden. Thanks again
Old 02-10-2006, 04:54 AM   #6
MV4ME
MV in the Registry:
[Brutale S]
Default
I too have noticed the rear brake is very light in application comparatively to the front but considered MV had designed it this way for high speed use. I have found its effectiveness to improve significantly with speed. My bike has done over 17000 km. I am curious too as to whether MV meant the balance of brake effectiveness to be like it is or if it is in fact an oversight or a concern?
MV4ME is offline   Reply With Quote
Old 02-10-2006, 06:58 AM   #7
Gladio
Gladio's Avatar
Default
My F4 has the old style MC and reservior mounted near the brake pedal under the cowling. MV changed the reservior mounting point on later models and I know my 910 Brutale has the reservior mounted under the tank, away from some of the heat. The rear brake on my Brutale works fine so far, but has low miles.
__________________
Jack
Old 02-21-2006, 08:42 AM   #8
Brian1100xx
MV in the Registry:
[Brutale S]
Brian1100xx's Avatar
Question Rear brake issues
Hi Folks, total newby to MV here but from looking at the siting of the rear brake cylinder and reservoir I may suggest that overheating of the fluid is to blame....has it discoloured any? if it has then it has been overheating, or has water in it,.......the solution as having had the same problem on an Aprilia RSVR clutch is to change fluid to DOT 5.1
Brian1100xx is offline   Reply With Quote
Old 02-21-2006, 08:52 AM   #9
Gladio
Gladio's Avatar
Default
I agree, fluid change should fix it. Will it require frequent changes even with DOT 5.1? I don't know and don't care too much.
__________________
Jack
Old 02-21-2006, 09:36 AM   #10
Brian1100xx
MV in the Registry:
[Brutale S]
Thumbs up Dot 5.1
Hi Gladio, 5.1 should take care of it and should only need changing as per recommendations i.e. every two years as fluid is hygroscopic.
Brian1100xx
vB code is On
Forum Jump
