*Free* 16M Diagnostic software - Page 5 - MVAgusta.net
log in
Forum
Thread Tools Display Modes
Old 04-23-2012, 06:27 AM   #41
merc07
MV in the Registry:
[F4 1000]
Default
Can I ask what cable you have?
The only issues I have heard of are with the cheaper blue ones.
There was some info somewhere about having to insulate the wires - I'll dig it out later
As for your ecu the software is only reading data so it won't damage anything.
Sounds like you still have a conflict somewhere
I'll speak to Esben - the guy that did the comms and see if we can resolve it
Adam
merc07 is online now   Reply With Quote
Old 04-23-2012, 10:50 AM   #42
Miko
MV in the Registry:
[Brutale S]
Default
Yes, indeed I have a cheaper interface (blue) but it has served me well for several months.
I'll make a reinstallation of the OS and again try to use old software, I will tell the result.
I'm glad to hear that despite all my ECU is safe.
Miko is offline   Reply With Quote
Old 04-26-2012, 04:48 PM   #43
merc07
MV in the Registry:
[F4 1000]
Default
Thanks for all the input....
New version 1.8 now uploaded with several changes.
Now includes 16m ecu error detection of processor, rom, ram, eeprom.
All the actuator tests are now available and working - much simplified layout.
Remember DO NOT connect the black lead from the OBDII connector if you have one, it uses the digital earth from the ECU.
The black OBDII connectors are much more stable.
Miko - need you to check your air pressure readout for me as per the pm I sent you..
Desmo - I'll get around to the offline log reads soon
Adam
Old 05-01-2012, 02:41 AM   #44
Miko
MV in the Registry:
[Brutale S]
Default
I have some images that may help you, but probably not all you need.
Unfortunately this weekend wasn't so happy for me and my Brutale, i was on the two days trip and in the middle of nowhere she just cut off during shifting between 2nd & 3rd, and now absolutely refuse to start.
As soon I get it in my garage it would be a first time to actualy "test" your software
Old 05-01-2012, 02:01 PM   #45
merc07
MV in the Registry:
[F4 1000]
Default
Hopefully it won't be much....lets see.
Version 1.9 now allows offline reading of the logs so you no longer need the bike connected up.
Example log file:
Marco has sent a log file that he saved while testing the changes that one of those memjet modules makes.
It has a dial 1 - 10 that simply changes the intake air temp value, and from that, the ecu uses it's fuel / air temp - idle trim to alter the injection value.
The log was done at idle only, you can see the air temp change points and the effect it has on the injector value.
There is also a fuel / air temp - open throttle trim plus the same for the advance, so plenty to think about when the temps get really confused from the Memjet.
Adam
Old 05-01-2012, 09:41 PM   #46
awiner
MV in the Registry:
[F4 1000]
awiner's Avatar
Default
Got all the cables and attempted to use the software today. Everything installed fine. (I do not have the serial emulator option as per what the sites the setup screen shows).
Upon turning on the ignition when told I heard a click and saw code at the bottom of the software window, however nothing ever changed nor did any additional tabs become available.
After a period of time I then even started the engine, still with negative results.
Ideas ?
awiner is offline   Reply With Quote
Old 05-02-2012, 01:11 AM   #47
merc07
MV in the Registry:
[F4 1000]
Default
Are you not using an FTDI obd2?
What cable and driver are you using.
Can you give me some more info on the code that is displayed.
Also at the very bottom of the screen there ae other numbers, what are these and do any of them change?
You may have to maximise the screen to see them.
Adam
Old 05-02-2012, 05:57 PM   #48
awiner
MV in the Registry:
[F4 1000]
awiner's Avatar
Default
Adam
Yes, I am using the blue FTDI ODB2 cable and a FIAT adapter with the red clip to the positive terminal of the battery. Black clip is unhooked as per your advice.
Stupid question but I assume on the F4-1000 the diagnostic port is the three pin cable that is just in front of the ECU box ?
Running 1.91 miaw
The hex codes at the bottom of the program when turning the ignition is is: 0x55 0xB0 0x80 0x80 0x85.
The bottom will say Disconnected 6, then change to Connected 6, then back to Disconnected 6.
Obviously something is recognized when the ignition is turned on but nothing else happens. No extra tabs become available/visable.
I am running Windows Vista on this laptop (however also tried this on my other Windows XP as well as Windows 98SE laptop with the same results).
FTDI Driver version is 2.8.24.0 (4/10/12) as sown in the USB Serial Converter tab.
USB Serial COM Port version is the same as above.
Once the numbers are displayed, they do not change.
I tried some very old drivers that came with the cable as well which ended up with the same results as above.
Old 05-05-2012, 02:39 AM   #49
Miko
MV in the Registry:
[Brutale S]
Default
Back on track !!
Almost embarrassed to say, the rubber tube between fuel pump and fuel filter came loose.
merc07 you have the screenshots in PM.
Old 05-05-2012, 04:40 AM   #50
merc07
MV in the Registry:
[F4 1000]
Default
Awiner -
Did you get any where with the info I pm'd you ?
I have just uploaded a version with a communication test v1.92
This should tell me how far you are getting with communication to the ecu. The ECUID box on the connection tab should fill with a number of asterisks, 0 to 12 of them.
I suspect you won't get any but we will see..
I also added an adjustable timing box for the initial communication delay - try that, see if it helps, 100ms is the standard.
Adam
vB code is On
HTML code is On
Forum Jump
