Rcs levers fitting issue - MVAgusta.net
log in
Forum
Go Back   MVAgusta.net > Models > F4
Thread Tools Display Modes
Old 01-10-2011, 02:06 PM   #1
MvMerito
MV in the Registry:
[F4S 750]
MvMerito's Avatar
Default Rcs levers fitting issue
My mechanic's fitting brembo rcs levers to my F4 but, on full lock the lever adjuster turn dial hits the clocks !
All I can think is to weld a new steering lock stop to prevent this, has anyone else had this issue and solved it more simply ??
__________________
"The first rule of Italian driving: Whats behind me is not important" 'The Gumball Rally' 1976
MvMerito is offline   Reply With Quote
Old 01-10-2011, 02:16 PM   #2
merc07
MV in the Registry:
[F4 1000]
Default
Don't worry about it. It's only the brake that just touches and it's only when it's just off full lock, won't do any damage to the clock, it just applies the brake slighhtly ! I think I lowered the rcs slightly any way so you don't have to raise your hand to grab the lever - That gave a bit more room from the clocks.
Just remember when your moving the bike around by hand !
You will soon get used to it.
Adam
merc07 is online now   Reply With Quote
Old 01-10-2011, 02:22 PM   #3
JDS
King of Bling
JDS's Avatar
Send a message via MSN to JDS
Default
Hey Double Agent James
Have you tried the later type F4 1000 bars ?.. They also improve the angle of the bar and makes it slighly more comfortable on the wrists..
Also, if you stopped bashing your bishop 5 times a day, your wrists won't ake as much..
__________________
Home of The Original CORSESuperleggera #01
MV F4 Corse Superleggera # 01
Ducati 1098R
ELR 1068cc
EMAIL : john@jandrdasilva.co.uk
“Life is a waste of time, and time is a waste of life. Get wasted all the time, and you'll have the time of your life!”....
JDS is offline   Reply With Quote
Old 01-10-2011, 02:33 PM   #4
jomarti1
MV in the Registry:
[F4 1000 R]
jomarti1's Avatar
Default
Yes, it happened to my bike, and it was fixed by my mechanic. I didn't want to have the bike like that. I know he changed the limmiter of turn by a couple of mm. It's perfect now, and I can still lock it, when parked. I'll try to ask him about it, but not sure when to come back and give you the info. Maybe somebody else will help you sooner.
jomarti1 is offline   Reply With Quote
Old 01-10-2011, 02:48 PM   #5
MvMerito
MV in the Registry:
[F4S 750]
MvMerito's Avatar
Default
Thanks all and hey John iv just got naturally well developed forearms, mostly from digging 6'x6 holes to re home dopey forum comment posters :-)
I could get used to the whole love thing but it will niggle me on an otherwise no holds barred project so I'd really like it solved.
Jo, your spanner man had the best solution, I'll pass on your info and wait for you to update me on how it was achieved. If you could maybe take a photo of lock stop? Its an image that will probably tell an explanatory story.
__________________
Old 01-10-2011, 05:10 PM   #6
Donsy
MV in the Registry:
[F4 1000 R]
Post Hhhmm
I had the same issue, I just moved the M/C closer to the throttle housing, it looks like you still have some room left on the bars ? Do not worry about removing those OEM locking pins in the switch gear, better to move them than have the front wheel lock up when you moving the bike around.
__________________
Manuals are here - http://www.teamdouble3racing.com/manuals
Donsy is offline   Reply With Quote
Old 01-10-2011, 05:19 PM   #7
postman_bat
MV in the Registry:
[F4 1000]
postman_bat's Avatar
Default
knob snot you could try adjusting the clock bracket may be pack it a bit
or dont bother with those levers and give them to a bat that will use them to there full potenial
__________________
life is not measured by the number of breaths we take
but by the moments that take our breath away
postman_bat is online now   Reply With Quote
Old 01-10-2011, 06:15 PM   #8
bstar360
No MVs in the Registry
Default
1. You could move the bars through the clamps a bit looks like you have a few mm.
2. Try to rotate the RCS on the bar.
3. Slide the RCS along the bar, I think that's pretty much what Donsy said.
I had a similar problem on the Duke.
bstar360 is online now   Reply With Quote
Old 01-11-2011, 12:35 AM   #9
theknurl
theknurl's Avatar
Wink
what Donsy said ^^^^
__________________
The Forum Curmudgeon
i'm not PC either
Noel-theknurl
ph. 310-540-4823 PST, GMT -8
email, PayPal; theknurl@yahoo.com
Skype; theknurl
theknurl is online now   Reply With Quote
Old 01-11-2011, 05:42 AM   #10
gotojoe
MV in the Registry:
[F4 1000 R]
gotojoe's Avatar
Default
James..Donsy's suggestion is correct. If you ever want to go to the later 0/e bars for ergonomic reasons I have a spare set..They look nicer too imho ! Anyway if you are so inclined ..I'll let you try them and see if you like..Be a good excuse for a blat out to Harboro'
joe
gotojoe is offline   Reply With Quote
vB code is On
Forum Jump
