| Register | FAQ | Members List | Mark Forums Read |
Thread Tools | Display Modes |
#1 |
![]() Join Date: Jun 2007
Hello my fellow Brutes, (SPU - the solid-state fuse box unit)
After significant research on this forum and following all guidance from the zen masters of all things Brute. (e.g. Do the basic checks first !! ). I purchased a replacement SPU unit from Vesuvio. ![]() I was, like similar owners, suffering from spurious electrical issues and can absolutely confirm the replacement has resolved the issues. My issues: No indicators, no head-light (high and low beam). Checks: 1. Bulbs 2. Connectors are free and clear from debris/corrosion or other crap - disconnect clear and reconnect ensure correct seating and seal 3. Fuses Whilst checking fuses - take a note of A800NNNN.....code on the inside of the fuse box cover. (different code for different series Brutes) 4. Order replacement SPU using the correct code Problem solved - not exactly a $50 replacement part....but if you've melted your SPU (as a result of its original design flaw being that it can over-heat) you may encounter any number of electrical fault combinations (e.g. bike still running with key out, lights flashing, no lights ...you name it). CAG / Randy / Fazer / Ed - can probably confirm, however the general impression I've established is that this problem was more a an issue with the early series Brutes and not the latter models. Just wanted to say thanks to the input from various people and summarise my experience ![]() Cheers
__________________
In the Garage today... '10 Nightster '05 Brutale S |
| Sponsored Links | |
Advertisement |
#2 |
![]() Join Date: Mar 2006
Nice
__________________
B4 750S [sold] B3 675R [waiting] |
#3 |
My 2007 910S also had some 'interesting' electrical issues.
It began with all 4 indicators flashing together continuously, even with the ignition off and key out! Even when I had pulled the indicator fuses, the indicator light on the dash continued to flash. Then the headlight began to also flash intermittently. Just received a new SPU from Vesuvio, plugged it in and all problems instantly gone. |
#4 |
Last year, gremlins nearly got me killed. So the new dealer here kindly fought my corner, and (at long last) with the replacement SPU under warranty, all gremlins promptly disappeared. Nice to know you can get them from Vesuvio, just in case fate comes out with the sequel – "The Return of the Gremlins".
#5 | |
No MVs in the Registry Join Date: Jun 2009
#6 |
I think they are about $330 euro + shipping from Vesuvio.
__________________
._ _ ._ _ | |/_| | |\/ ----------------------------------------------------------------------- Subscribe to the NZMV Mailing List 2009 Meeting Gallery | 2011 Meeting Gallery | 2012 Meeting Gallery ----------------------------------------------------------------------- 4. NEXT Brutale... (not here yet.... ) 3. Kawasaki Z1000 - The mule. 2. MV Agusta Brutale 910R - Binned, written off. ![]() 1. Honda VTR250 - My first bike and learner!, sold. |
#7 |
+ 1 Gremmin
__________________
#8 |
![]() Join Date: Apr 2010
a couple of you have commented on my post about issues with my brute. I've been riding it the past 2 weeks in spite of the problems. today at work when i went to move it out of the way of the landscaping people it wouldn't start. GRRRRRRRRRRRRRR. so I pushed it into the service center, by this time all the display lights decided not to work to. and on a last ditch effort to not order the SPU I pulled the battery and had them put it on the tester/charger. 5.2 volts, hopefully all my issues are resolved after it gets a good charge. PLEASE PLEASE PLEASE GOD. I don't want to spend 500ish bucks.
#9 | |
I finally broke down and ordered a new SPU. While it is not here yet, i'm certain that all my issues will go away with the new unit. The current issue i'm seeing is that the headlight and high beams don't work. The bike not shutting off issue seemed to have resolved itself a few days later--after letting the bike sit.. But I *cannot* ride the bike knowing that failures loom ahead.. |
#10 |
So the verdict is ........................ need a new SPU, fuel pump won't stop priming,
so now i guess i just have to fix it right and all will be well in the world of my motorcycles emailed vesuvio as the part i need is not on their website for an 04, hopefully a reply will be had in the near future. So until they get back to me and i get the part there will be lots of![]() |
