What are Radial Valves? - MVAgusta.net
log in
Forum
Go Back   MVAgusta.net > Models > F4
Thread Tools Display Modes
Old 06-19-2006, 05:11 AM   #1
markone
No MVs in the Registry
Default What are Radial Valves?
..at the risk of sounding stupid, I've never heard a complete description/explanation of what exactly MV mean by their interpretation of radial valves. Their heads look the same as any other to me. Can anyone enlighten me plz?
markone is offline   Reply With Quote
Old 06-19-2006, 06:24 AM   #2
hb88xx
hb88xx's Avatar
Default
they are angled in two directions (ball shaped cumbustion chamber). no paralell valve stems:
__________________
4,5Mg~3Al~2Ti~Fe
Http://tinyurl.com/b4-312rr
backlight
hb88xx is offline   Reply With Quote
Old 06-19-2006, 08:49 AM   #3
markone
Default
ah - ty for that. so basically it's a hemi.
MV's idea of radial valves are not the classical accepted type seen on early 4 stroke engines
i'd like to see the complete valve train if anyone has such a graphic
Old 06-19-2006, 10:33 AM   #4
altoon
altoon's Avatar
Send a message via Yahoo to altoon
Default
fyi, they cut the cam lobes at an angle. that's how they make sure the cam lobes fully contact the top of the valve stem bucket.
alex
altoon is offline   Reply With Quote
Old 06-24-2006, 04:28 AM   #5
hb88xx
hb88xx's Avatar
Default
__________________
4,5Mg~3Al~2Ti~Fe
backlight
Old 06-27-2006, 04:56 AM   #6
agusta01
agusta01's Avatar
Default
Great photos... thanks for sharing
agusta01 is offline   Reply With Quote
Old 06-27-2006, 05:21 AM   #7
markone
Default
alex
thanks - that was the other thing i was trying to figure out.
Old 12-23-2011, 02:50 PM   #8
abazhle
abazhle's Avatar
Default
The radial valve layout does not actually refer to a difference in the valves themselves, but the way they are positioned in the cylinder head. This arrangement allows improved port size and shape, valve included angle, and improved combustion chamber shape. It may also contribute to better cooling. The main benefits are better breathing and better combustion efficiency, leading to better power output. This is extremely important in a short-stroke engine design, because there is very little stroke length to draw-in the intake mixture, or to push-out the exhaust gases. So breathing capability is paramount. As we know, the MV engine is the shortest stroke 750cc 4- stroke motorcycle engine ever made. This short stroke contributes to the high-revving abilities of this engine, and in a design like this, revs mean power. At nearly 14000rpm there is an extremely short time for the mixture to enter the engine, so the flow rate must be maximized. The radial valve layout is an effective way to maximize the flow, and improve the efficiency of the combustion by better chamber shape so that the fuel can be efficiently transformed into power at the high revs that are seen in this engine. With short- stroke designs, there is little inertial mixture flow to aid in the induction of the mixture beyond the BDC point of the stroke. Even with longer duration of the cam profiles, it hasn't enough time to keep drawing much after BDC. So it all must flow in on the initial draw of the descending piston. Anything that can be done to improve this initial mixture flow will do a lot to help the power output. Having the added benefit of better chamber shape, with less valve area being shrouded by the chamber walls and cylinder walls gives us the second benefit of getting the best burn out of the additional mixture that has been inducted into the cylinders. Then the radial layout of the exhaust valves has a similar effect in getting the exhaust gases out of the cylinder. I am not certain, but I believe this was first done in some Ferrari F1 engines. As we know today's MV 4-cylinder engines were derived from a Ferrari F1 engines in the early 90's.
abazhle is offline   Reply With Quote
Old 12-23-2011, 03:00 PM   #9
proddieracer
proddieracer's Avatar
Default
I had an RFVC Radial Valve Honda XR500RE in 1984. Positive we would have had radial valves in something advanced like a Rudge or similar. Nothing is really new.
__________________
If Barbie is so popular, why do you have to buy her friends ?
proddieracer is offline   Reply With Quote
Old 12-23-2011, 03:25 PM   #10
Matty
MV in the Registry:
[F4S 750]
Matty's Avatar
Send a message via AIM to Matty
Default
__________________
Matty
Matty is offline   Reply With Quote
vB code is On
Forum Jump
